Question about Sony Cyber-shot DSC-W110 Digital Camera
Lens not moving the display shows - turn the power off and on again...but nothing happens
    Novelist:
  • 82 Answers
This is a typical drop defekt, or a pressur on the camera lens. if you have the camera in the shorts and sitting one the camera or you have make any pressure on the camera lens. its very probably that you must change the lens bloc. have you specific knowledge to substitute the lens bloc.???? if you dont have no idea how you can substitute le lens. is not a work for you. if you have a little knowledge of eletronic. you can go to ebay international seller of america if you want, find the exact lens block of your camera,. any seller if you buy the lens give you a guide to make the exact job. a lens block cost from 25 to 40 euro. but if you make one error you keep away the camera and the lens
Posted on May 30, 2010
My Cyber Shot DSC W55 when i open it the lens keeps moving forward and backward and then something shows on the screen which says First "ACCESS" then the next one is "Turn The power off and...
Error: TURN THE POWER OFF AND ON AGAIN or Access is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Feb 24, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Nikon D80 Err
You did not mention what error mesage you got. If it is a flashing "F--" then it has something to do with your lens.
This usually happens to lenses that have an aperture ring. Do the following:
1. Turn off your camera.
2. Move the aperture ring clockwise and lock it
3. Turn on the camera and see if this works
If this does not work, unlock the aperture ring and move it counter-clockwise then lock it again.
This should fix your problem
Jan 01, 2010 | Nikon D80 Digital Camera with 18-135mm...
F-- on Nikon D90's display
Lense and body connection problem...Try removing and replacing he lens. Also you can try to gentley turn the lens on the body to make the contacts touch better...
Jul 05, 2009 | Nikon D90 Digital Camera with 18-105mm...
Dropped the camera, now no view shows in window
Two possible problems have happened. What does the display show when the camera trys to power on? If it says error on the top of the display error 31 you have a stuck lens barrell. If it shows nothing you may have broken the display. Let me know what happens I will answer back.
Jun 08, 2009 | HP PhotoSmart M627 Digital Camera
Camera was dropped. Now it will turn on, but after a few seconds, lens begins to move in and out for about 3-5 seconds, then a messag is displayed: Pleaase turn camera off then on again". Doing this r
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Problem with lens
throw it on the floor again
IT WORKS!!!!! YYYYEEEEEEEEEEAAAAAAAAAAA
Jul 10, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Digital Camera Fault
ACCESS error could happen when lens gets stuck but if it happens when lens moves back and forth without problem it usually means that where the lens assembly plugs into main system board connection is loose. These connections are held in place by a very small thin fragile plastic clip and a few drops could be enough to snap it but not do any other noticeable damage to camera. Camera would need to be opened to see if clip is broken or maybe cable just needs to me reinserted. Either way only open camera if no longer under warranty and you are somewhat handy
Mar 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Fujifilm Finepix A340
Hi, you can't fix the problem yourself.Because i think there is a problem with lens assy. and to fix this problem you have to repair or replace the lens assy. so pls take it to the Fuji shop. good luck........
Jul 24, 2006 | Fuji FinePix A340 Digital Camera
Sony Cyber-shot DSC-W110 Digital Camera Logo
90 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
