Question about Janome Memory Craft 10000
What is a hasp device driver? I'm installing digitizer 10000 on a windows xp computer and it says the hasp device driver is not installed. What do I need to do?
2 Suggested Answers
  • 15 Answers
SOURCE: MC 10000 Digitizer 10000 Error Message
Try downloading the updates for your software from Janome Global, downloads, software. Version 1 needs patches to make it compatible with XP. The most current Version for the 10000 software is 2.21, and the upgraded program is Digitiser pro/MB , a much more stable and far easier version to work with. The upgrade has to be purchased via a dealer or direct from Janome.
Posted on May 20, 2008
I had to buy new computor got a 25 pin put in for dogle downloaded hasp drive but still says security device not found. Help!!!!!!!!!!
Welcome to Fixya
May i know the brand and model of the device that you are trying to connect to your computer? Where are you seeing the error message?
Your response will be highly appreciated.
Thank you for using Fixya!
May 16, 2011 | Bernina Artista 180
I have memory craft 950.computer crashed and had to relace- now have windows 7 and can not install my cstomiser 10000 plus (ver1.0
There are software updates for the Customizer 10000. See: http://content.janome.com/index.cfm/LearningCenter/Software_Updates . Drivers and installers have changed over time.
I do not know the limitations of the update software.
I hope this helps.
(The other thing to try is the compatibility mode. This may work directly - right click on the installer and choose Properties. Then choose the compatibility tab and set the Program to always run as compatible with XP. Then right click again and choose Run as Administrator. If this doesn't work, another option is to run a second computer with an older version of Windows. You can use a true second computer, a dual boot computer or a virtual computer (which takes a portion of memory from the main computer but doesn't require a restart). If you have Windows 7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. The other options require a valid Windows license for the older OS. Install your Customizer in the older OS as you would normally install the software.)
Mar 10, 2011 | Janome Memory Craft 10000
How to repair a bernina hasp lock
HASP or security device dongles were used on earlier Artista software. If your machine still has a parallel port and the HASP devie is on the connector then you probably upgraded windows over time. There is a XP device driver fix you may need to install. I recently loaded the ancient Artista software into a modern machine so I know it can be done. Just need to have the proper hardware support.
If all your trying to do is communicate with the machine from the PC then look into an USB to SERIAL converter and use the Artlink software from Bernina (free). Has much of the function that the earlier software did except for limited edit capabilities.
Jan 02, 2011 | Bernina Artista 180
Connecting my Memorycraft 10000 to a PC
Have you got the cable that is compatible with your machine. If you are running Customiser 10,000 on your computer it should be fine otherwise it could be that you are running Windows7 not sure about that though.
Feb 05, 2010 | Janome Memory Craft 10000
Why "Digitizer 10000", which used to work on my computer with WinXP SP2, is not working on Windows 7? After installing the software, I click on the button to start the program, but the mistake comes. Help...
Windows 7 is not compatible to your Digitizer 10000.
You may need a software driver to configure it with
the new operating system. You should know that there are lots of things that work with Windows XP and won't work with Win 7. So try surfing the internet
at Microsoft to address your problem.
Oct 14, 2009 | Janome Memory Craft 10000
Need a driver to install my digitizer 10000 disc
Try this link - it should be the one you want!
Then, according to Janome's recommendations, follow it up with this download.
Mar 27, 2009 | Janome Memory Craft 9000 Computerized...
Need Windows XP USB driver for Memory Craft 10001
contact me back at dbfm13@aol.com and i will send you all the drivers i have.
when i got mine working, i believe sometimes it is just by LUCK that things work.
Jan 12, 2009 | Janome Memory Craft 10000
JSMC850 DRIVER
I had the same problem. I download the latest version of easy transfer. The driver is in this version. My computer still could not find the driver. I went into the program file where easy transfer was downloaded and copied the driver file for Windows XP or whatever version you use, to a cd. Opened up my device manager found the usb controller with a yellow question mark, double clicked the yellow question mark and clicked reinstall driver. Then you choose the custom install and tell it to look on your cd. It should install the driver. I restarted my computer. Your files should transfer.
Sep 17, 2008 | Janome Memory Craft 10000
Apr 16, 2008 | Janome Memory Craft 10000
Changing from windows XP to Vista
Unfortunately there is no fix for users of version 3 who have upgraded to vista.
The version 4 of Artista software does work in Vista. I have tested this and it appears to me to be related to the software "dongle" protections.
Nov 29, 2007 | Bernina Artista 180
Sewing Machines Logo
713 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
