Question about Maytag Neptune Washer
Washer continues to fill with water, no matter what function is set on the dial and will not spin water out of machine. Door will not unlock
  • Maytag Master
  • 43,501 Answers
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Washing Machinewasher continues to fill with water, no matter - 2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Asker's Testimonial " Thank you, I was also told that it may be the fill valve?? " - dsmith1695
Posted on May 31, 2010
Washer only fills with water
Good Afternoon Thomas, thank you for your post!
I understand your washer only fills with water. Do you mean the washer fills but then it stops operating, doesn't spin, doesn't spin, or fills with only hot or cold water? If you could elaborate on the model number and exactly what is not working on your appliance, I will be better able to assist you.
In the meantime, if your washer is in fact only filling with water but not functioning in any other way; disconnect power from your washing machine for roughly two minutes. Confirm that the door is securely latched and select a cycle. If the issue continues, it could be number of other underlying causes - it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards!
Jan 27, 2014 | Frigidaire Washing Machines
Ftf530fs1 not filliing not spinning
Hello rickclancyar - Is the washer make a humming noise? If so either the drainage hose or pump is clogged and needs to be clean. If not, then the unit could possibly be experiencing an issue with the control board, wiring failure, faulty pump, timer, or door lock assembly. Consult a professional for an accurate diagnosis and to assist with the repairs.
Feb 11, 2013 | Frigidaire FTF530FS Front Load Washer
Hello The washing machine is not going through
The lid switch has failed. It will not spin because it is a safety device.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 22422 Top Load Washer
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
Frigidare washer hums loudly and doesn't fill with water
I figured out what was wrong with it. We narrowed it down to the pump or the timer. We determined that since the machine was spinning when the lid was down and it was spinning no matter where the dial was set, we figured it had to be the timer.
We did have one issue getting the dial off the washer. The trick to it was to remove the pin from the middle of the timer and the dial just came right off.
It was an easy fix really and the timer cost us $95.00 Hope this helps someone else in the future.
Jan 05, 2009 | Washing Machines
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine will not work and flashes 12 minutes
remove bottom cover look for tech sheet usually on right side of cabinet at bottom fh is usually a water fill issue drain may be siphoning water may be slow filling or bad flow meter flow meter may be harder to diagnois but try tapping lightly with screwdriver (it's the round object left side with 2 small hoses attached ) slim chance may be pressure switch left side rear corner
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
