Question about Samsung D840 Cellular Phone
Replacing outer screen
Hi my d840 has a lot of dust on the inside of the outer screen ,can you please tell me the easiest way to remove the outer screen from the phone without taking it all apart thanks karl
  • col2229 Jun 04, 2008
    hi, can anyone tell me how to change the screen on my samsung d840 please thanks
There is no way to do it except taking it all apart, sorry!
Posted on Apr 21, 2008
SOURCE:
Ive got an alternator belt on a 1978 mercedes 450sl and the belt needs to go on the inside pully whats the easiest way. [email protected]
The only way to replace an alternator drive belt that is on an inside pulley is to remove the outer belts before the inner one can be fitted.
To fit inner belt, loosen the adjusting clamp and mounting bolts on the units that tension the outer belts such as the aircon compressor and power steering units and moove them to loosen the belts and then remove these belts. Once these belts are off, check them for wear and cracking of the rubber on the inside surface and if suspect it would pay to replace them as well. Loosen clamp and mounting bolts on the alternator, if not already done so, and moove alternator so that alternator belt can be fitted.
Retension alternator belt and tighten clsmping and mounting bolts Refit other belts in turn and tension and tighten clamping and mounting bolts.
Correct tension is when belt is pushed on the longest run between pulleys with a 10 Kg force. Belt should deflect a maximum of 8 mm.
Feb 26, 2011 | Mercedes-Benz SL550 Cars & Trucks
SGH D840 Screen Blank out and No Sound
did you try removing batteries and putting them back
Jul 28, 2008 | Samsung SGH-D840 Smartphone
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Fan sounds is very high
it may be lots of dust inside the computer. the more dust inside, the less airflow. i suspect your computer might be getting too warm, which makes the fans spin in overdrive. if you open up the pc, be sure to remove all power sources before you start fiddling with screwdrivers... (it's for your own safety)
Jun 24, 2009 | Dell Optiplex GX280 (99301) Motherboard
Hilux surf lower wishbone bushes need replacing .is it a hard job
If you are experiencing grinding noises when turning, it is usually the top strut bearings above the springs that transmits noise inside.
These get the worst of salt spray - so often turn to dust. You will need to drop the suspension to check this area out.
It could be that this ball joint is suspect too, but you can only tell with the pressure off it.
Also check other rubber bushes when the suspension is off, as wear on an inner one may not normally be noticed. Uneaven tyre wear is usually an alignment problem - so have the tracking checked by a garage with Laser equipment.
Jan 03, 2009 | 1993 Toyota Pickup
Cleaning inside Canon 50mm /f1,8 II
you can have a look here:
http://www.ejarm.com/photo/ef5018iidis/
and here:
http://nis-lab.is.s.u-tokyo.ac.jp/~ybando/rgb_filter/disassembly.pdf
HTH,
Jean-Marie.
Sep 28, 2008 | Canon EF 50mm f/1.8 II Lens
I have dust under outer lens on my 75-300mm f/4 -5.6 III USM
Front element? You can remove this without alignment worries. The lens zoom mechanism tends to **** in the dust.
Have a look at the front element outer ring. There are 3 black screws. Remove these using jewellers screwdriver (y'know, a very small posi-drive one!). Remove this plastic outer ring. Now you can see three small silver screws, that are about the same size - when you try to unscrew them, they just rotate...
This is as they are not screws, but as mentioned elsewhere - they are plugs (if you notice, they are slightly under the casing. Get a small flat bladed screwdriver, and gently prise them out. Now you can just drop the front element into something sensible - like a microfibre cloth (give it a clean whilst you're there.
Get a rocket blower (NOT canned air), and blow away the dust, and you can use the microfibre cloth (or similar) on the small inner front element.
Then replace the outer front element - you will see where it drops into place - there are plastic guide tabs. Push back the silver 'screw' plugs.
Then screw back on the plastic outer ring and you're done - takes 20 minutes at the most.
Jul 02, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Samsung d840
you should take the phone to a mobile service center and have it done there.
you can also source that on youtube.com
Jun 20, 2008 | Samsung D840 Cellular Phone
How To Remove The Fixed Lens From The Olympus E-10 For Cleaning
The easy fix is to buy a new camera. Or trade up to Canon equipment that is easier to clean.
-BLL63
Mar 08, 2008 | Olympus Camedia E-10 Digital Camera
Phone dead
take the phone into the nearest mobile service center closest to you and have them service the phone for you.
Feb 16, 2008 | Samsung D840 Cellular Phone
Samsung D840 Cellular Phone Logo
56 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
