Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Not cooling Power on but will not cool down. Was working and for no apparent reason quit freezing and cooling. Can hear the fan running but not cooling.
  • Maytag Master
  • 1,606 Answers
Sounds like the overload / relay has gone out . This is the piece plugged onto the side of the compressor . Easily replaceable , just take the model number with you to get the correct part .
Posted on May 31, 2010
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerNot cooling - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
My 2003 VW Jetta air conditioning is cooling for a few minutes and sometimes longer and then it stops cooling. The fan continues to run but the compressor apparently stops running.
Have you watched the compressor in action? The compressor is driven by the fanbelt which turns a pulley on the compressor shaft, but there's an electric clutch that disengages the pulley from the friction plate attached to the compressor shaft. You should hear a click when the clutch engages and disengages. Do you hear that? Can you see the friction plate turning with the pulley or does it stay in one position while the pulley turns? If if works for a bit then stops turning, you may have a damaged friction plate such that it doesn't engage with the pulley. Take your car to an auto A/C specialist and let them examine it. It's also possible that the relay that sends 12 volts to the clutch is intermittent and needs to be replaced.
Jul 22, 2015 | Heating & Cooling
My amana abl1922fes has quit cooling several times in the 5 years i've had it. We unplug it, let it set overnight and plug it back in and it cools fine for a few months when it quits cooling again. Can...
when it stops cooling, you will see some ice build up in the freezer. Letting it sit unplugged melts the ice and you will see some water under the fridge. Connect power and it works. Cause: don't overload the fridge and the freezer. Make sure the doors close snugly. Clean all lint build ups by vacuuming under and behind the fridge after switching off power.
Mar 06, 2014 | Amana Refrigerators
GE GSS25QGMC-WW refrigerator is runnig, but not cool or freez. When I unplus power for 30 min to an hour and plus power back on. The compressor is runnig, cooling about 12 hours. After that I hear the fan...
What is the internal temperature set to? If the fan is running it sounds like you have the temp too warm. It's not going to be cooling on 1-3 (sort of cold not really).
Set temps as far "cold" as possible, wait a about 3-4 hours, check it. If you continue to have issues, you need to have it serviced by a repairman.
Mar 20, 2010 | Refrigerators
Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Jul 03, 2009 | Refrigerators
Amana SPD26VW runs, lights on, does not freeze
I called Amana and found the "sealed systems" are still under warranty. It cost me $85 for a service call and the fridge is working. The problem was a plugged "capillary line."
Jun 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Satellite A305-S6883 freezing for no apparent reason
It's an overheating issue.
Sometimes you can fix it by updating the bios.
Make sure you do it while the laptop is really cooled off or else you could do serious damage.
You'll need to check Toshiba's support page for the latest bios for your model.
You should probably hook up a regular fan as well to keep the laptop cool for the time being.
If the bios upgrade doesn't work you'll need to open the laptop up, clean out the dust with some more air, and then I'd suggest cleaning / reapplying some Thermal compound to the Cpu and heat sink.
That should take care of the problem. If the fan still spins slow you might need to replace it.
Jun 13, 2009 | Toshiba Satellite A305-S6883 Notebook
My laptop is freezing for hours at a time.then i shut it down,and retart but it also takes for ever,some times all day is this due to the freezing or is this another problem .and can it also be ovet...
you need do some thing follow:
1) clean the cpu fan and sink(around there dirdy)
2) check the cpu fan is running and stop ok when power on if running go next
3) check the cpu fan, is there any running and stop then see it run again before the laptop freezen?
4) if the fan not running again before freezen that your fan control circuit out of work on the motherboard need to repair
5) if the fan running control ok that the fan can run and stop and run again. you have to add a EXT cooling base under the laptop
hope to help you solve it
May 09, 2009 | Dell Latitude D600 Notebook
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
443 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
