Question about Toshiba Satellite M35X-S161 Notebook
When powering up, fan comes on for about 5 seconds, but screen stays blank, then fan goes off....had jack soldered, but still does not work...i just want my laptop back!!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
Have you checked your RAM?
Try to replaces or swap together.
Posted on Jun 01, 2010
  • test815 Oct 28, 2010
    Read this article, it may be your solution:
    Why my Toshiba laptop suddenly shuts down by itself without warning?http://www.laptoprepair101.com/laptop/20...
My screen wont turn on
have you been already clean the memory using with an eraser.
Jul 10, 2012 | Acer Computers & Internet
I'm sure this is a problem for most. HP Pavilion dv9205us starts up, fan engages, Led's light up, drive attempts small start, but stops and after 15 to 20 seconds shuts down with a 1 second flash...
Hello.
Could be a power issue.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jun 05, 2011 | HP Pavilion dv9205us Notebook
Not booting. The LED light on the start button appears when the button is pressed, then after around 20 seconds the fan starts. the fan runs for about 5 seconds then the system goes off. The cycle...
Hello.
Hope this helps.
May 27, 2011 | Dell Latitude E6400 Notebook
Will not boot up, screen is blank power light comes on for a few second, then turns off
Either your DC jack is bad the motherboard is bad or the power supply is bad. The DC jack on that one is NOT soldered in and fairly easy to replace if you know how to tear it down. Toshiba uses a clip in clip on DC jack instead of soldering them to the board. Start by ohming out the power supply make sure its placing out the correct amperage. Thibk its around 1.58 amp at 19volts. You can see 4 sure looking at the label on it. If its good I would take it to a qualified shop to have the DC jack and board tested to see which is causing your power issue. The average replacement laptop board is $285 not including labor. DC jacks run about $5 but the labor should run around $100
Sep 17, 2010 | Toshiba Satellite A200-0ET00X Notebook
Screen comes on then goes off after 5 seconds
You may have power supply DC filter caps problem or the back light inverter circuits, need to inspect the inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 29, 2010 | Proview PL713B 17" Flat Panel LCD Monitor
Monitor goes blank after 5 secons
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | Computers & Internet
Power light comes on green for a second then goes orange, then red with no test screen just stays blank
Check the CPU, If ok then check the CRT neck pcb supply and pcb area..may be dry solder..
Jun 25, 2009 | Sony PremierPro SDM-P232W/B (Black,...
The TV cuts off frequently. The screen is blank & no sound.
It is probable you have a poor soldered connection on the power supply board, hence the erratic timing of the TV going on & off. If you are competent with a soldering iron look for dry jointed soldering on the board. If not have a service engineer take a look at it for you.
Jun 24, 2009 | Panasonic Televison & Video
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Toshiba Satellite M35X-S161 Notebook Logo
232 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
