Question about Samsung Digimax S630 Digital Camera
E button for effects
Hi, i just bought this camera second hand. It says in the manual that if u press the E button you can do different effects but when i press it the only option i get is to change the colour. is there no other options like special effects etc?
Yes there is, when you view a picture, then press the E button and alot of fun things will come up!
Posted on Apr 17, 2008
Delete button not working ( Canon EOS 400D )
1) Put lens or camera cap on, go to a dark room to be sure if you want
2) Take JPG+RAW shot, maybe at different ISO and shutter speeds, one could be 30 sec/ISO 1600
3) Press menu, go to Settings 2 tab, and press sensor Cleaning: Manual, then OK. Wait for 30 seconds or more (is this necessary?) The mirror inside opens, but since you are not removing dust, this has really no effect, but it seems that after doing this, the camera remaps the dead pixels.
4) Take another JPG+RAW shot, compare with shots from 2) - same shutter and ISO
Aug 04, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
I bought a second hand Mamiya 645 Af but as soon as I load a film it shows a error message ERR 01 .... what is that ?
From the manual:
"If the error display is not canceled when the shutter release button is pressed again, insert the Dark slide, half-press the shutter release button while pressing the roll film holder's manual film advance button to wind up the film, then contact your nearest Mamiya agent or service center."
If you need a manual, you can download one from
http://butkus.org/chinon/mamiya/mamiya_645af/mamiya_645af.htm
Aug 04, 2011 | Mamiya 645AF Medium Format Camera
How do i set timer
Press cursor-down (marked with a one-handed clock) to cycle through the different self-timer modes. Your choices are off, two-second delay, and ten-second delay. Start the self-timer by pressing the shutter release button as normal.
Feb 25, 2011 | FUJIFILM FinePix J30 Digital Camera
How do i set my picture timer to take a hands free pic with my nikon coolpix l20?
Press left on the multiselector (marked with a one-handed clock). Use up/down to select ON from the menu and press OK. The self-timer will fire the shutter ten seconds after you press the shutter release button.
Dec 13, 2010 | Nikon COOLPIX L20 Digital Camera
Hi i have sony h7 and wan to reset to factory
Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jun 26, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Can't find how to use self-timer
The manual I find is no use either.
The self timer button is on the back, the lowest button of all. The manual says you can set it to 2 seconds, 10 seconds or 10+2 seconds. But not how to use it.
Try pressing this button and see if the rear display changes to different times.
Then press the shutter button to try it out.
Hope this helps a bit.
Mar 19, 2010 | Cameras
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Black and white photos
Press MENU SET. Now scroll through the menu items using the up and down arrow buttons until a item named COL. MODE is highlighted.
Press the right arrow button, then select the color effect with the up and down buttons.
Set the effect by pressing MENU SET.
Jul 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Grainey photos
Firstly check the ISO setting isnt up high, this will introduce more noise than a lower setting.
A reset may help press and hold the +/- and AF buttons for more than 2 seconds (page 44 of the manual)
else there is a full reset button just below the USB port (page 129 of the manual)
you can download the manual from ftp://ftp.nikon-euro.com/Manuals/ppY_QFonPh/D80-En_05.pdf or
http://services.yesmembers.net/yes/content/D80_en.pdf
Unlikely but possible, depends what you mean by grainy, check the sensor hasnt a fine coating of dust, not on a nikon but I had a kind of grainy effect after photographing in a print works where they used a very fine dust, I foolishly changed lenses and was left with a fine dust coating on the sensor which gave a speckled/grainy effect...
best of luck
May 26, 2008 | Nikon D80 Digital Camera with 18-135mm...
Samsung Digimax S630 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
