Question about Kenmore 500 6952 Dryer
I BOUGHT NEW KENMORE 500 WHEN TURNED ON IT ONLY HUM
I BOUGHT NEW KENMORE 500 WHEN TURNED ON IT ONLY HUM AND WOULD NOT START ALL EFFORTS TOMAKE IT WORK HAS NOT BEEN SUCCESSFUL
    New Friend:
  • 35 Answers
Check the belt to see if its broken
or off the Drum or Idler Pulley.
If the belt is in place
(there is usually a mark on the drum where it should go)
then I would call the place where I bought it,since it's new, & tell them to fix it or you will call:
The Better Business Breau & Sears Headquarters.
I'd give them at least a week to make it right....log everything that you do.
Good luck,
Vinnie
Posted on Sep 13, 2010
I have a Kenmore 500 series top load washer. It will fill but the motor just hums in all the cycles. Stops humming when the door is opened so the switch is good. The gears on the timer feel and sound...
After removing the transmission, I turned the input shaft and could watch the output shift twist, in one direction its should be turning as in the spin mode, and the other direction the output shaft should turn back and forth as in the agitate mode. I could see the trans was not turning in the spin mode. I replaced the tranmsission ($175) and it fixed the problem.
Dec 29, 2012 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 18, 2011 | Kenmore Dryers
I bought kenmore 500 washing machine dryer,
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 30, 2010 | Kenmore 62602 Electric Dryer
Kenmore 500 dryer hums when the start button is pushed. THe drum does not turn.
Dryer2_bing.gif Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
May 10, 2010 | Kenmore 500 6952 Dryer
I need the installation Instructions for a Kenmore 500 Dryer
While this manual is not for your specific Kenmore dryer, the Kenmoreinstall directions for the model in the manual will be the same. Start on page 5
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502231.pdf
Nov 21, 2009 | Kenmore 500 6952 Dryer
I have a Kenmore 500 washer model 28532 and it just hums doesnt want to drain at all
the mod# is not good.if it hum's, it could be a blockage in the water pump or the motor is bad.
Nov 17, 2009 | Kenmore 15864/15862 Top Load Washer
Trouble with the spin cyle.
Bad motor. Easy to replace. Worth the effort.
To find out how, click HERE
Feb 04, 2009 | Kenmore 24982 Top Load Washer
Kenmore micowave oven over range
Usually this is due to your diodes going bad. I recommend replaceing the magnatron at the same time though.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Kenmore 80 series dryer, won't turn on
Thanks for the question When you push the start button was thera hum if there is a hum when you push start you need a new motor THanks for the question The appliance doc
Jul 18, 2008 | Kenmore 63942 Dryer
Kenmore 500 6952 Dryer Logo
121 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
