Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I bought a 52 in. Nov.3 2006, and the menu keeps poping in and out and the sound goe's down by it self. I did talk to a tech and he say's it's the circut board needing replaced. He say's these tv's arn't worth fixing. Well I would think a $1000.00 tv that is only 4 year's old would last longer then this.
  • RCA Master
  • 8,617 Answers
That problem is caused by the small signal board. You can get a replacement signal board from www.tvrepairworld.com they cost around 75.00
Posted on May 31, 2010
The monitor's menu keeps poping up
if you manually press the button that accesses the 'menu' at other times, does it work ? (as in maybe the menu button is stuck down ?)
Aug 28, 2012 | E-Machines eMachines Desktop PC
I have a 6 year old(nov 04) Sony KV-30HS420 that turns off all by itself. The screen goes to green and the picture fades to black. The sound will keep playing for a few seconds then the TV will turn itself...
If the screen goes rather bright green it is one of two things:
1. It is possible it is a shorted green gun in the picture tube, there are three of them, red, green and blue guns in neck of the tube.
2. The other possible reason is there is a problem on the small circuit board at the end of the picture tube, this model should use three IC chips, one for each red, green and blue.
Being intermittent makes it hard to tell but ask the shop if they tried the self check this set should have. With the set turned off use the original Sony remote and hit Display, 5, vol down, and power.
If the set has a self check (it should) a box will appear on the screen with up to five items with a zero to the right of each, items will be like AKB, OVP, etc, and if any have something other than a zero to the right it pinpoints what happened.
Sets with this feature record each event where something goes wrong, ANYTHING other than a 0 indicates what failure was detected.
If I was to make a guess there will be a number next to AKB, which is Anti-Kine Bias, this means the picture tube or something on the board at the end of it drew too much current and the set's shut down circuit turned the set off.
I actually fixed one of these where both the blue and red IC chips on that board were bad, needless to say, I replaced all three of them.
Any good shop would know about the self check and even if the set did not shut down in the shop the self check would point to the area where the problem is.
Let me know if you need more help or find a error code.
REGARDS, SD TECH
Dec 01, 2010 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Rca flashing the menu screen
a professional. Electronics go threw a self diagnostic to check for problems. it sounds like it's found one.
Jun 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The menu keeps poping off and on
The cuircit board that contains the front buttons is at fault. you have two options remove the front button panel and use remote only or replace this cuircit
Feb 28, 2009 | RCA HD52W58 52" TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Oct 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
Autoconvergence option is GONE!
There is a blown fuse and diode located next to the flyback transformer I believe the location is DL231 and the fuse is FL231
Sep 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv keeps shuttinf off
does the picture ever come up?...the processor on this set shuts down the set when there is a problem. then generates an error code log. a tech should be able to read these to help determine the problem
Nov 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
