Question about Mitsubishi VS-5043 50" Rear Projection Television
Sound , but no picture
This began as a slow start to get picture. Now has evolved into no picture , but good sound. Had a few flashes of color described as a prism just prior to going black. Will work normal again after many hours or days. sound but no picture
    Genius:
  • 3,422 Answers
The only solution to fix this problem is to get itrepaired.Th repair will cost anything between $300-$400. the problem is with the convergence ICs.
My guess, without the benefit of some hands-on testing, would be the high voltage flyback and HOT are defective.
Few troubleshooting steps you can try:
1)Do a hard reset by unpluging all the cords for 4hrs and then plug it back.
2)The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
Goodluck,
Please don't forget to rate the solution as fixya..
Posted on Apr 08, 2008
  • 2,326 Answers
Can you provide model number of TV?
  • 78 Answers
It sounds like the problem is in the circuit board. The TV should go in for professional repair - electric shock is no fun. Good luck.
The picture on my tv slowly started going out and began making a weird sound. Kind of like an internal fan was turning on and off. The power on button has "Timer," "Lamp," and "Standby/Temp" flashing. What...
It sounds like the color wheel has failed and will need to be replaced. I would recommend calling a technician to do this job. You can call 1-800-samsung to find the nearest service center.
Jul 20, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Pictures get ghost image & colour veriation
You get a picture with sharp and correct colored parts as well as parts blurred with wrong colors?
I assume this only happens indoors, when you use the flash?
It sounds like you are using Slow Synchro flash mode.
Try switching the flash mode to Auto instead.
May 04, 2010 | Fuji FinePix S7000 Digital Camera
Stability system engaged wtf?
This system usually kicks on when it thinks the wheels are spinning out. Thus...it slows the wheels to regain control. It can also happen in the rain when the car senses it is hydroplaning. If none of these things are possible, it's probably a broken sensor or something.
Jul 23, 2009 | Cadillac Eldorado Cars & Trucks
Philips 42fd9954-175
Hi, and unfortunately I am facing the same issue. My TV blinks GREEN LED for a few seconds then starts flashing RED led. The result I hear from this is that it is the SSB Panel and the estimated cost for service is $600.00 it sounds like you are STARTING with the problem. I began that way too. If you are under warranty, call Philips NOW!
May 13, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Motorized sound and picture quality poor and jumpy
your husband is correct it is most likely your color wheel very common and it will effect the picture. what will happen soon is your tv will not turn on. The cost is two possiablities. color wheel replacement 225,00 part is 80,00 complete light engine in rear cases cost is 650.00 dollars . I hope this helps
thanks doctor video leadingedgeeletronics since 1987
May 04, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Optoma projector
would need a model number to get this nailed down but it sound like you have a DLP projector, this might have a color wheel in it, sometimes when this fails you get flash of colors as the color wheel slows down then the unit sences that the color wheel has stoped and shuts down the unit
Mar 07, 2008 | Optoma Multimedia Projector
TV has sound but no picture. It would work after turning on and off a time or two. Now all i get is sound and a black screen.
Feb 13, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
