Question about Frigidaire ATF6000ES Front Load Washer
My frigidaire front load washer keeps saying error every time i push a button
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the error code that you are getting on your Frigidaire front load washer and also confirm the model no# ATF6000ES for further assistance.
Thanks
Rylee
Posted on May 30, 2010
2 Suggested Answers
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
Code E 21 Error on Affinity Washer Front Loader
I've had problems starting my washer because the door does not close properly, and then I get an error or pau code
What has worked is to unplug the washer for a minute, close the door, and then plug it back in. it then starts normally with 2 pushes on the start button
Jul 06, 2014 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire affinity front load washer, my power went out and came back on, now the washer keeps beeping 3 beeps about every 30 seconds. Error code E91 will flash up when I push any button
Hi bsful1 - Typically, E91 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Apr 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
E41
Control board thinks the door switch is open. You may need a new door switch.
Dec 23, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer will not start error code says "LOC"
hold the option and select buttons at the same time for several seconds and it will "unlock" the control panel hold it for a very long time keep them pressed as you turn the dial
Dec 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washer wont start it says LOC when i push the star button then err this is a front load frigidaire gallery
This indicates there is an error with the door lock mechanism. It will most likely need to be replaced. This will prevent the dryer from working and is a safety feature to prevent injury while the dryer is in operation. It is fairly quick and cheap to repair.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Jun 16, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Error Message
what is the error message ?
machne can lock on to mush soap
May 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front load washer doesn't start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
59 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
