Question about Supra Washing Machines
Front Loading supra washing machine model SW 6550 - AF
My washing machine is having leakage problem
it is leaking from underneath down below
please advise what to do
thankyou
  • sabir fazle Apr 08, 2008
    it is leaking on front side underneat i checked the door seal grey gasket gasket is in good condition and there is no leak from the door please advise
2 Suggested Answers
Yozzer6821
  • 116 Answers
SOURCE: front loading washing machine is having leakage problem
You need to work out where the water is coming from, either the front, back left or right hand side to give you an idea what/where to look.
Front - Open the door and check the door seal (usually grey rubber round the door) look for splits, chaffing, damage.
Rear - check the connection to the pump, there will be a (Black) rubber hose from the drum housing about 12-18"long, check for splits, connection etc.
Check and remove the pump itself, Isolate the electricity, to remove - disconnect the outlet hose from below the sink or upstand, lower the outlet hose to the floor and syphon off the water into a bowl from the machine, there will be some even if the machine appears empty. disconnect the plug on the pump (2 wires), disconnect the hoses from the pump (2 off) and check inside the hoses, bra wires, socks etc. look inside the pump for foreign objects, the pump can be wasily split open via 3 screws normally, refit in reverse order.
Top - remove the top cover usually 2 screws at back or side and will slide slightly to remove, check hoses to drawer and the hose below drawer to top of the drum housing, check the inlet solenoids at the back (where the water hoses connect).
hope this helps
Posted on Apr 08, 2008
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
I NEED TO DOWN LOAD THE INSTALLATION MANUAL FOR SUPRA FRONT LOADING MODEL SW60BH8FL
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 17, 2011 | Washing Machines
LG front loading washing machine...top detergent drawer won't pull out
try one of these!
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
John C
Jun 21, 2011 | LG WM-2277HW Front Load Washer
My front loader washing machine shows F 9 on the digital screen which relates to water leakage. I have had this problem recitified previously, wherein water somehow leaked into the bottom of the machine,...
Sorry but Whirlpool 'F09' does state 'overflow'. It could be that the overflow sensor is being a bit keen i.e. malfunctioning, and needs a service call ;-0(
Sorry again,
John C
Apr 08, 2011 | Whirlpool Washing Machines
Washing machine is leaking
you can remove the front panel(3 screws across the very bottom lip) from there you wil gain acess to view the underneath, as the macine is operating to pin point where the leak is coming from
Nov 23, 2008 | Kenmore Washing Machines
Front loading washing machine is having leakage problem
hope this helps
Apr 08, 2008 | Washing Machines
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Mar 15, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Leak in washing machine
can you tell where the water is hitting the belt from is it in the middle of the wash tub or from the outside of the wash tub please let me know if its from the middle of the tub its probably the seal that keeps the agitator from leaking, and if its from the side the in lines from the water spicket or the valve that controls hot and cold in the machine could be leaking, please look closely and try to see where the wateris dripping down from. thank you, then let me know
Dec 21, 2007 | Washing Machines
Aeg washing machine
you may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
Mar 21, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
363 people viewed this question
Top Supra Washing Machines Experts
Andrew Taylor
Andrew Taylor
Are you a Supra Washing Machine Expert? Answer questions, earn points and help others
