Question about Toshiba Satellite A215-S4747 Notebook
I cant find the Wifi switch on my toshiba L505d. the only thing I see is what looks like a volume know next to the wifi led but when I turn the knob it does nothing
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
To enable or disable wireless communication, use the Hot Key
Fn+F8.
To use the Hot Key Cards:
1 Press and hold the Fn key.
The TOSHIBA Cards appear along the top of the screen.
I cant find the Wifi switch on my toshiba L505d. - 1219ab8.png (Sample Image) Hot Key Card display
2 Click the Card for the system function to be modified.
The selected Card is displayed full-size with its available
options below it. All other Cards are again hidden from view.
3 Click the desired option.
To use a Hot Key Card using a hot key:
2 Press the hot key associated with the desired function.
The associated hot key card appears at the top of the screen
with its available options below it.
3 To cycle through the displayed options, hold down Fn and press
the hot key repeatedly. Release the Fn key when the desired
option is selected.
NOTE
Posted on Jun 01, 2010
Restore FN + F8 key to reactivate Wi-Fi on Toshiba Satellite L500
My laptop didnt enable the wifi with the fn+f8 key.
I even reset the cmos and nothing.
Then I went to toshiba drivers website and after installing the "thku" "toshiba hotkey utility" the fn+f8 start working and enable/disable the wifi. It now shows a popup windows when I press the fn+f8 key.
Before the wifi led was always off. Windows detected the wifi device but nothing on the wifi available list.
Now the led is always on, starts orange when I turn on the pc and blue when connected.
Oct 05, 2012 | Toshiba Satellite L500 Series Notebook
Why is my Toshiba Satellite L505D-GS6000 Wifi driver not found?? After resetting, checking device manager, trying fn+f8, and dowloading the driver it still doesn't show up!!!
Sounds like a bad wireless card or the card slot.I would try replacing the wireless card.When wireless cards go bad they either cause the laptop to not boot,low or no signal reception or the card isn't seen at all by the motherboard or operating system or .both.If it isn't showing in device manager either with a caution sign or installed the card is most likely bad
Mar 08, 2012 | Toshiba Satellite A135-S4727 Notebook
How do you turn on the WiFi feature?
Pressing the keys Fn + F1 at the same time will enable or disable the built in wifi.
Mar 02, 2011 | Coby PC Netbook 1ea
Don't know how to setup wireless toshiba satellite pro 6100 pc notebook
Most Toshiba 6100s come standard with wireless cards installed. If you're unsure, just turn on the WiFI antenna switch (near its SD card slot) and see if the WiFi access LED lights up (the WiFi LED is the rightmost LED on the front of the unit) -- if it lights up, then you've got a stock Wireless card in your system.
Email me if you can't determine which card you have.
Jan 15, 2011 | Toshiba Satellite Pro 6100 Notebook
The toshiba satelite L505d-s5965 cannot connect with the wireless
There are two things you have to first check on:
1) Check if the wifi turn on button is set to on or use the Fn keys on keyboard for that.
2) Check in the computer devices to see if the driver is installed, not conflicting and working well.
Dec 04, 2010 | Toshiba Satellite L505-S5966 Notebook
My Toshiba Satellite L305D-S5940's wifi stopped working
Its posable that the antenna is worn out. Just buy a wifi card and insert it in the slot, they work better anyway!!!
Jul 25, 2010 | Toshiba Satellite L305D-S5940 Notebook
I have a Toshiba Satellite L500 and the wifi won't work. Have read other forums and apparently it's a faulty wifi card problem. How can I get this fixed without shipping it around the world. I'm in the...
  • Hi, I hope that you are still monitoring this "Website" for a "Solution?" I might be able to help you. Follow these instructions, and we will be able to get you connected. I'm familar with the "Computer Model" that you have, so lets get started! First, click on the (Start button) to open the "Start Menu," next "Type" in the (Search box): "Toshiba." In the Program list; find the Toshiba Application Installer, and "select" to open. The Driver Installer "appear." Now you can select, and install the Wireless Drivers; click on the "Next" button, in the ("choose an item...") window, select the By Name: Wireless LAN Driver, and to the (right), click on the "Install" button. To finish click on the "Exit" button. Note: Follow all instructions thereafter exactly. "I hope this help you, let me know, if possible"
Jan 15, 2010 | Computers & Internet
Can not connect to wifi due to wireless switch
I assume you have a laptop or notebook. If you look closely at your keyboard, you'll notice a couple of keys next to the spacebar, usually on both sides, that have something like "Func" printed in blue or another color.
Now, if you look at the rest of the keys on your notebook, you will see that some have two
functions: the desired character key, and another, in the same color as that special
function key.
If you now look at the topmost row of keys, or the 'function" PF keys, it's likely that
they too have a second function, depicted by a small icon in the same color. The icon
you're looking for should look like a radiating antenna, and it may have on it (or elsewhere in the notebook) a small (usually blue) LED that comes on that comes on when WiFi is turned on.
The combo key action you refer to means that you should press the special function key next
to the spacebar first, and then the key that has the icon, to toggle WiFi on or off.
In other cases, there's a recessed button along the edge, either on a corner, or on the sides of the notebook, with a similar icon depicting an antenna of some sort, and it usually has an LED that comes on to indicate WiFi is active.
If all fails, your user's manual is the best source of information to find the key/key combination you need, since not all notebooks/laptops have these keys/buttons in the same place.
Apr 06, 2009 | Sony VAIO LT38E T8300 2.4G 4GB 1TB BDRRW...
Toshiba Satellite M35X-S163
There's a handy Wi-Fi on/off switch as well as a volume wheel located on the system's right edge,just move it round and move it and there is a light indidcator on top of the keyboard that shows the wifi is on and when u move that wheel the wifi light will be off.
Jan 16, 2009 | Toshiba Satellite M35X-S163 Notebook
Wifi switch not hooked up - stuck in off, how can I override swit
Did you check to see if the wifi was properly plugged in?
Usually this happens after they replace the motherboards or anything else that makes them unplug things.
I would check to make sure it's plugged in and check the wifi card if it don't plug in and make sure it's compatible.
Happy Holiday
Dec 24, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite A215-S4747 Notebook Logo
1,274 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
