Water is slowly leaking into the drum even though
Washing machine problem. Water is slowly leaking into the drum even though it is switched off.
    Brigadier General:
  • 4,088 Answers
One or both of the water inlet solenoids is/are leaking. They are just inside the cabinet where the outside water lines connect. If you have a lot of sand coming in with your water, you might install a whole house filter to trap it. If sand is getting into the solenoid valve seats, that can cause the leaking condition. Hope this helps!
Posted on May 30, 2010
Lg outer drum leak
Basically you need to open the water tap with the washing machine off. If water still flows in, then your water inlet valve has to be replaced. If the level continues to rise and does not switch off, then either there is a leak in the pressure switch pipe or the pressure switch is defectiv(very rarely) or their is a blockage in the hole entering the brum onto which the thin pressure pipe connects.Either of these could be the problem.
Jun 24, 2012 | Washing Machines
Why is water leaking from the bottom of the the washing machine?could the drum be to full?
It could be a bad tub seal, hole in a hose, or even the drain pump.
I would need your model number to be able to tell you how to check these parts.
Sep 27, 2011 | Frigidaire Washing Machines
My washer is not draining and has slowly filled with water
im not an expert but it might be a leak or somethings backing up or there could be a blockedge in the drain.
Apr 27, 2009 | Kenmore Washing Machines
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Whirlpool duet washer leaking water into the drum when not used
water leakin in tho the drum is sign of a faulty water inlet valve, not shutting off water supply to machine, it continues to trickle in , in beween washes. you can turn off the water supply between washes see if this helps, and if it does then youll know its the water valve
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
Kitchenaid front loading washing machine
check your drain hose see if its too low lower than the tub or too far down in the drain as this will cause a siphon action
Mar 02, 2008 | Washing Machines
Water flow when off
you need to replace your water valves one is leaking
Feb 13, 2008 | LG WM-2077C Front Load Washer
Drum filling up with water when not in use.....
only source is leaking inlet valves and only way to cure is to replace
May 14, 2007 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
215 people viewed this question
Top Washing Machines Experts
