Question about Samsung SL202 Digital Camera
How to open the cd rom for windows on my mac (old compi was windo
I can't download pictures to my new mac about the software CD-ROM for my Samsung SL 202 was for my old windows computer. How do I download the software to my mac?
    Brigadier General:
  • 11,967 Answers
You could use a card reader to download to a folder you create on your desktop.
Posted on May 31, 2010
Trouble installing my Samsung SCX-4200 printer
Good day Sir, That is common macintosh problem. There is described "driver not installed" at product List Window after you click Add and select USB. I suggest Reintall the software and make sure that you are using a high-quality cable.
Installing software Samsung scx-4200 for Macintosh
Verify the following before you install the software.
Operating System - Mac OS 10.3x or higher
RAM - 128 MB
Free Disk Space - 200MB
  1. Make sure that you connect your printer to the computer. Turn on your computer and printer.
  2. Insert the CD-ROM which came with your printer into the CD-ROM drive.
  3. Double-click CD-ROM icon that appears on your Macintosh desktop.
  4. Double-click the Mac_Installer folder.
  5. Double-click the Mac_printer folder.
  6. Double-click the Samsung SPL2 Installer icon.
  7. Enter the password and click OK.
  8. The Samsung SPL Installer window opens. Click Continue and then click Continue.
  9. Select Easy Install and click Install.
  10. After the installation is finished, click Quit.
Have a nice Day.
Dec 24, 2009 | Samsung SCX 4200 All-In-One Laser Printer
My samsung software cd-rom for my S1030 digital
It is not compatible with Windows 7. You could get a card reader and download your pics to a folder you create on your desktop.
Nov 22, 2009 | Cameras
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
Non-compatable software
Right Click Driver Installation, (open cd rom, not auto play) and click properties. on the tab click run in compatibility for and select xp. it should work. This works for multiple products.
Jan 07, 2009 | Nikon Coolpix 2000 Digital Camera
Samsung cd-rom is misplaced
serach the internet for the drivers for you mobile  I.e  the software that runs the transfer of files
for that you could simply make a google search for the   "samsung d820 drivers " or "samsung d820 software"
and you would get an appropriate link also you could go to the manufactrers site and search fot the software and download it.
Dec 27, 2008 | Samsung SGH-D820 Cellular Phone
Computer
Hi Diviola, you have no choice but to buy a CD-ROM drive. They are not as expensive as you might think. You're windows CD can format the hard drive in you're computer before installing windows. Some people can use a USB memory stick but in order to copy the windows CD software to the memory stick you'll still need a CD-ROM drive. A 2GB or 1GB memory stick will cost as much or more than a CD-ROM drive. Please click on the link to see some prices for a standard CD-ROM drive.
http://www.zipzoomfly.com/jsp/ProductList3.jsp
& here.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3287198&CatId=87
The link above is a CD-ROM drive & can also make CD-RW's (RW stands for re-write).
You can replace you're CD-ROM drive you're self. Just do not disconnect the cables from you're old CD-ROM drive untill you have the new drive. Connect the cables to the new drive (one at a time) as you disconnect them from the old CD-ROM drive.
Double check that the cables are tightly connected before you power up the PC. Load you're windows CD into the new CD-ROM drive & when you start you're PC up windows will start to load.
When you receive the new CD-ROM drive & if you need help connecting & running anything. You can come back here & ask questions. I'll help you through this.
Luck!
Mike
May 10, 2008 | Creative Labs Sound Blaster Live! 5.1...
Dvd rom detecting problem
You need to find what DVD reading and CD and also DVD burning software you had, then download versions of the programs compatible with Win 98--then they should work fine. Your CD/DVD drives will be ignored until you get the correct burning software installed. Go t Samsung, which hopefully will have the appropriate downloads for Win98. If Samsung no longer has what you need, find any software for Win98 such as Roxio, or hopefully freeware, and you should be back in business.
Feb 12, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Wont install
Forget the CD Rom
This suggests you are running a PC with XP and it is not a signatured software.
Windows however can download images without the software
Just plug it in and let Windoes do the work
Jan 22, 2008 | Vivitar ViviCam 35 Digital Camera
Installation problem
yah.. borrow some PC with cdrom working.. compy all files from installer cd to USB flash drive.. then install cam to your pc without cd rom.. or you can download installer from internet..
Jan 01, 2008 | Philips J44414
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Open Questions:
See all Samsung SL202 Digital Camera Questions
Samsung SL202 Digital Camera Logo
224 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
