Question about Fisher and Paykel GWL11 Top Load Washer
How to remove the water pump - Fisher and Paykel GWL11 Top Load Washer
  • luisa_sgro May 31, 2010
    your pump is located under the machine bowl.please have a look at it and tell me if it has a fan on it, either a black one or red one. please reply and i can guide you throe the removal of the pump
  • Deanna Everly Jul 30, 2013
    THE FAN IS RED
  • 343 Answers
Empty the machine of water, because any left in it will run out the drain port.. disconnect power...Lean machine back to access the pump, which is on the RHS under the bowl.....Turn the pump anti-clockwise (Like a light globe)....It will be prevented from turning by a small plastic latch which will have to be 'unlatched'...Once this is done the pump can be rotated and withdrawn from the pump port...Wires should be disconnected to allow enough rotation......Reverse procedure to replace...Pump resistance should be no less than 33 ohms if 230v, or 7 ohms if 120v......Good luck....Nomess
Posted on May 31, 2010
Change the water pump
  • Tools Required
  • J 43651 Water Pump Holding Tool
  • Remove the thermostat housing.
  • Remove the water pump access plate from the front cover.
  • Remove the right hand fender liner.
    1. Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
    Drain the coolant from the water pump using the plug at the bottom of the pump.
    1. mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
    Install the J 43651 into position.
    1. Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
    2. Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
    3. Remove the 3 inner water pump sprocket to water pump blots.
      1. Important: Be sure to remove both water pump bolts from the front of the engine block.
      Remove the 2 water pump bolts.
      Remove the rear 2 water pump bolts.
      1. Remove the water pump.
      2. Remove and discard the water pump O-ring seal.
      Installation Procedure
      1. Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
      Install a NEW water pump O-ring seal.
      1. Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
      Using the guide pin, align the pin with the water pump holding tool.
      1. Position the water pump against the engine block and hand tighten the water pump bolts.
      2. Notice: Refer to Fastener Notice.
      Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt.
      Tighten the bolts to 25 Nm (18 ft. lbs.).
      1. Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
      2. Remove the J 43651.
      3. Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
      4. Install the right hand fender liner.
      5. Install the thermostat housing.
Aug 29, 2011 | 2006 Pontiac Solstice
Need instruction for replacing water pump 2004 GMC Envoy 4.2 liter engine.
TO REPLACE WATER PUMP.FIRST YOU HAVE TO DRAIN THE COOLANT SYSTEM. REMOVE AIR INTAKE DUCT AND RESONATOR. REMOVE THE RADIATOR SHROUD AND FAN CLUTCH ASSEMBLY REMOVE THE DRIVE BELT. REMOVE WATER PUMP PULLEY.YOU NEED A PIN SPANNER WRENCH OR STRAP WRENCH TO HOLD WATER PUMP PULLEY WHILE LOOSEN WATER PUMP PULLEY BOLTS .YOU CAN BUY STRAP WRENCH OR RENT PIN SPANNER WRENCH AT AUTO ZONE PARTS STORES OR OTHER STORES HAS TOOLS CAN BE RENT. ONCE WATER PUMP PULLEY REMOVED. REMOVE THE WATER PUMP MOUNTING BOLTS. REMOVE WATER PUMP. IF WATER PUMP STUCK YOU CAN TAP WITH SOFT FACE HAMMER OR A LONG PIECE OF ROUND WOOD.WHEN WATER REMOVED.YOU NEED TO CLEAN THE SEALING SURFACE CAREFUL DONT SCRATCH SEALING SURFACE. YOU CAN BUY CAN OF SPRAY GASKET REMOVER.CLEAN SURFACE GOOD THEN WIPE WITH LACQUER THINNER OR ACETONE.THEN GET WATER PUMP NEW GASKET MATCH HOLES UP WITH GASKET TO WATER PUMP. ONCE HOLES MATCH UP APPLY RTV SEALANT ON BOTH SIDES WATER PUMP GASKET. THEN PUT GASKET ON WATER PUMP THEN INSTALL WATER PUMP TO VECHICLE.TORQUE WATER PUMP BOLTS TO 89 INCH LBS .TIGHTEN WATER PUMP PULLEY BOLTS TO 18 FT LBS THEN PUT EVERY THING BACK VISA VERSA.
Aug 26, 2011 | GMC Envoy XL Cars & Trucks
How long does it take to replace a water pump on Pontiac Aztec?
It takes near to 1.5 hours to replace the water pump on Pontiac Aztec. The procedure to replace the water pump is as follows:--- Water Pump Replacement ---------
Removal Procedure :
  1. Drain the cooling system until the coolant is below the level of the water pump.
  2. Remove the drive belt guard.
  3. Loosen the water pump pulley bolts.
  4. Remove the drive belt.
  1. Remove the water pump pulley bolts.
  2. Remove the water pump pulley.
  1. Remove the water pump bolts.
  2. Remove the water pump.
  3. Remove the water pump gasket.
  4. Clean the water pump mating surfaces
  1. Install the water pump gasket.
  2. Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley. Loosely install the mounting bolts.
  2. Install the drive belt.
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 inch lbs.) .
  1. Install the drive belt guard.
  2. Fill the cooling system.
  3. Inspect the cooling system for leaks.
  4. That's it.
Nov 18, 2010 | 2001 Pontiac Aztek
How to replace water pump 2003 alero. 3400 engine.
Removal & Installation 2.2L Engine To Remove:
  1. Disconnect the battery ground cable.
  2. If equipped with an automatic transmission, remove the exhaust manifold..
  3. Drain the cooling system.
  4. Raise and safely support the vehicle.
  5. Remove or disconnect the following:
    • Right front wheel and tire assembly.
    • Access plate on the water pump sprocket from the timing cover.
  6. Install J 43651 water pump sprocket holder or equivalent to the water pump sprocket.
  7. Use the access plate bolts to attach J43651 to the engine front cover.
  8. Remove or disconnect the following:
    • Bolts that secure the sprocket to the water pump.
    • Bolt that secures the engine block to the water pump.
    • Bolt that secures the engine front cover to the water pump.
    • Feed pipe that joins the thermostat housing to the water pump. chevy_cav_02-04_wp.gif
    • 2 Bolts that secure the water pump to the engine block.
    • Water pump.
To Install:
  1. Use a threaded stud in the hub to align the water pump sprocket.
  2. Install or connect the following:
    • Water pump.
    • 2 bolts that secure the water pump to the engine block.
    • Front cover bolt and the bolt that secures the engine block to the water pump. Tighten the bolts to 15 ft lbs (20 Nm).
    • 2 of the bolts that secure the water pump sprocket to the water pump.
  3. Remove the threaded stud.
  4. Install the last bolt.
    • Tighten the bolts to 89 in lbs (10 Nm).
  5. Remove J 43651.
  6. Install the access plate on the water pump sprocket to the timing cover.
  7. Install the access plate bolts.
    • Tighten the bolts to 18 in lbs (10 Nm).
  8. Install the front fender liner.
  9. Install the right front tire and wheel.
  10. If equipped with an automatic transmission, install the exhaust manifold.
  11. Fill the cooling system.
  12. Connect the battery ground cable.
2.4L Engine To Remove:
  1. Disconnect the negative battery cable
  2. Drain the engine coolant.
  3. Remove the exhaust manifold.
  4. Remove the coolant intake pipe as follows:
    1. Remove the coolant inlet pipe bolts.
    2. Remove the wheel and tire assembly.
    3. Remove the engine splash shield.
    4. Remove the bolts from the transaxle-to-engine block brace and remove the brace.
    5. Remove the radiator hose from the coolant inlet pipe.
    6. Remove the coolant inlet pipe to oil pan bolt.
    7. Remove the coolant inlet pipe, thermostat and seal.
  5. Lower the vehicle.
  6. Disconnect the heater hose quick connect from the heater outlet pipe.
  7. Remove the front timing chain cover and the chain tensioner.
  8. Unfasten the water pump-to-cylinder block bolts.
  9. Remove the water pump-to-timing chain housing nuts.
  10. Remove the water pump and cover mounting bolts and nuts.
  11. Remove the water pump and cover as an assembly. Separate the two pieces after removal.
  12. Clean the mating surfaces.
To Install:
  1. Install the water pump cover to the water pump assembly.
  2. Install and hand tighten the pump cover mounting bolts.
  3. Install water pump cover assembly.
  4. Install and hand tighten the cover-to-block mounting bolts.
  5. Install and hand tighten the water pump-to-timing chain housing nuts.
    • Tighten the water pump-to-timing chain housing mounting nuts to 19 ft lb (26 Nm).
    • Tighten the water pump cover-to-water pump mounting bolts to 124 in lb (14 Nm).
    • Tighten the water pump cover-to-engine block bolts starting with the bottom bolt first to 19 ft lb (26 Nm).
  6. Install the heater hose to the water pump pipe.
  7. Using new gaskets, install the exhaust manifold.
  8. Install the oil level indicator and tube.
  9. Connect the brake vacuum tube to the cam housing.
  10. Raise and safely support the vehicle.
  11. Install the catalytic converter.
  12. Install the coolant inlet pipe.
    • Tighten the inlet pipe-to-oil pan bolt to 19 ft lb (26 Nm). Tighten the coolant inlet pipe bolt to 124 in lb (14 Nm).
  13. Install the timing chain and tensioner.
  14. Lower the vehicle.
  15. Connect the oxygen sensor.
  16. Fill cooling system and check the system for leaks.
3.4L Engine To Remove:
  2. Drain the cooling system.
  4. Remove or disconnect the following:
    • Drive belt.
    • Water pump pulley bolts and pulley.
    • Water pump bolts, pump and gasket.
    • Clean the water pump mating surfaces.
To Install:
  1. Install or connect the following:
    • Water pump gasket and pump.
    • Water pump bolts.
      1. Tighten the water pump bolts to 89 in lbs (10 Nm).
    • Water pump pulley and bolt until snug.
    • Drive belt.
  2. Tighten the water pump pulley bolts to 18 ft. lbs (25 Nm).
  3. Fill the cooling system.
  4. Check for leaks.
  5. Connect the battery ground cable.
Aug 31, 2010 | 2003 Oldsmobile Alero
How to take off the water punp
1. Drain the cooling system until the coolant is below the level of the water pump. 2. Remove the drive belt guard. 3. Loosen the water pump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulley bolts. 6. Remove the water pump pulley. 7. Remove the water pump bolts. 8. Remove the water pump. 9. Remove the water pump gasket. 10. Clean the water pump mating surfaces. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump Notice: Refer to Fastener Notice in Service Precautions. 3. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.). 4. Install the water pump pulley. 5. Install the water pump pulley bolts. 6. Install the drive belt. Tighten the water pump pulley bolts to 25 Nm (18 inch lbs.). 7. Install the drive belt guard. 8. Fill the cooling system
Aug 13, 2010 | 2002 Buick LeSabre
Remove and replace the water pump buick rendezvou 2003 cost and do it yourself instructions . can i do it myself concerned with loosening the serpentine belt and needing special tools?
Visit my Blog here
Jul 21, 2010 | 2002 Buick Rendezvous
Water pump removal
REMOVAL & INSTALLATION
2.0L Engine
  1. Disconnect the negative battery cable.
CAUTION Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant.
  1. Drain the engine cooling system.
  2. Raise and safely support the vehicle.
  3. Remove the lower radiator hose from the water pump.
If the lower radiator hose is hard to reach on the back of the water pump, remove the hose at the radiator and after the water pump is ready to be removed, pull the water pump away from the engine block until there is enough room to remove the hose from the pump.
  1. Lower the vehicle.
  2. Remove the accessory drive belt.
  3. Remove the timing belt covers and the timing belt as outlined in this Section.
  4. Remove the four water pump retaining bolts.
  5. Remove the water pump.
To install:
  1. Thoroughly clean all sealing surfaces.
  2. Install a new water pump gasket and the water pump onto the cylinder block.
  3. Tighten the retaining bolts to 12-15 ft. lbs. (16-20 Nm).
  4. Reinstall the timing belt and the timing belt covers as outlined in this Section.
  5. Reinstall the accessory drive belt.
  6. Raise and safely support the vehicle.
  7. Reinstall the lower radiator hose.
  8. Lower the vehicle.
  9. Fill the engine cooling system.
  10. Reconnect the negative battery cable.
  11. Start the engine and top off the coolant as necessary. Check for leaks.
2.5L Engine
Before continuing with this procedure, be sure three new water pump retaining bolts (W701544) are available. Due to their torque-to-yield design, the bolts stretch and cannot be reused.
  2. Remove the water pump pulley shield.
  3. Remove the water pump drive belt.
  4. Remove the water pump inlet and outlet hoses from the water pump.
  5. Remove the three water pump to left cylinder head retaining bolts.
  6. Remove the water pump and water pump housing from the vehicle.
  7. Remove the water pump to water pump housing retaining bolts and separate the water pump from the water pump housing.
To install:
  2. Install the water pump to the water pump housing using a new gasket and install the retaining bolts. Tighten the retaining bolts to 16-18 ft. lbs. (22-25 Nm).
  3. Position the water pump and water pump housing and install three new torque-to-yield retaining bolts into the left cylinder head.
  4. Tighten the new retaining bolts to 11-13 ft. lbs. (15-18 Nm), then rotate the retaining bolts 85-95 degrees.
  5. Reinstall the water pump inlet and outlet hoses to the water pump.
  6. Reinstall the water pump drive belt.
  7. Reinstall the water pump shield.
  8. Fill the engine cooling system.
  9. Reconnect the negative battery cable.
  10. Start the engine and top off the coolant as necessary. Check for leaks.
Hope helps (remember comment and rated this).
Jul 07, 2010 | 1996 Mercury Mystique
How do you replace a water pump in an aztec?
Notes Water Pump Replacement
Removal Procedure
Jun 17, 2009 | 2001 Pontiac Aztek
Water pump replace
Water Pump Replacement (3.8L)
Removal Procedure
  1. Drain the cooling system.
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
    3. Remove the power steering pump and reposition.
    4. Remove the water pump bolts.
      2. Remove the water pump gasket.
      3. Clean and inspect the water pump mating surfaces.
        1. Notice: Refer to Fastener Notice in Service Precautions. Install the water pump bolts.
          • Tighten the long water pump bolts to 34 Nm (25 ft. lbs.) .
          • Tighten the short water pump bolts to 22 Nm (16 ft. lbs.) .
            2. Install the water pump pulley bolts.
              • Tighten the bolts to 13 Nm (115 inch lbs.) .
            1. Install the power steering pump.
    5. The Whole Thing I Know You Didnt Want to hear that about The P/S Pump Thats why I Did More Reserch you seemed to Know what You are Doin They get the Best of us though Hope this Helps & RATE ME PLEASE
Feb 03, 2009 | 2005 Chevrolet Impala
How Do i replace Water Pump on 98 Chevy Metro
  1. Remove the negative battery cable.
  2. Drain the engine cooling system.
  3. Remove the air cleaner assembly.
  4. Remove the A/C compressor suction pipe bracket (if equipped).
  5. Loosen four water pump pulley bolts. Do not remove the bolts.
  6. Raise the vehicle. Support the vehicle. Remove the right lower splash shield.
  7. Remove the right lower splash shield.
  8. Remove the A/C compressor drive belt (if so equipped) by releasing the tensioner pulley and removing the belt from the crankshaft and compressor pulleys.
  9. Loosen the generator adjusting bolt (1), pivot the generator and remove the water pump/generator drive belt.
  10. Remove the crankshaft pulley.
  11. Remove the water pump pulley (four bolts).
  12. Remove the timing belt.
  13. Remove the oil level indicator (dipstick) guide tube.
  14. Remove the upper generator adjusting bracket from the water pump (one bolt).
    1. Remove the rubber seals from the water pump.
    2. Remove the water pump mounting bolts and nuts.
    3. Remove the water pump and gasket from the vehicle.
    4. Clean the water pump and the gasket mating surfaces.
    5. Install the water pump.
    6. Secure the water pump with mounting nuts and bolts. Tighten Tighten the water pump mounting nuts and bolts to 13 Nm (115 ft. lbs.).
    7. Install new rubber seals (1) to the water pump (2).
    8. Install the upper generator adjusting bracket to the water pump (one bolt).
        • Tighten the upper generator mounting bracket bolt to 23 Nm (17 ft. lbs.).
      1. Install the oil level indicator (dipstick) guide tube.
      2. Install the timing belt.
      3. Install the water pump pulley.
      4. Finger-tighten the four bolts.
      5. Install the crankshaft pulley.
      6. Install the water pump/generator drive belt to the crankshaft, water pump and generator pulleys.
Nov 20, 2008 | 1998 Chevrolet Metro
Fisher and Paykel GWL11 Top Load Washer Logo
80 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
