Question about Whirlpool LEV4634JQ Electric Dryer
Idler pulley too loose on LER4634EQ2 MODEL
BELT BROKE ON MY DRYER AND THE IDLER
WAS LAYING AT BOTTOM OF THE BASE AND HAS
BEEN TOO LOOSE TO REAPPLY NEW BELT? NEED TO
KNOW HOW TO FIX PROBLEM AND REAPPLY MY BELT!
  • floresw13 May 30, 2010
    yes thanks alot couldnt figure out why so much slack after replacing so this helped alot much appreciated
    President:
  • 949 Answers
Here is a picture and image of how the belt routes around the idler pulley, if the pulley is bent or loose it may need replaced. The part number for the idler assembly on your dryer is 691366.
Let me know if you have questions.
Posted on May 30, 2010
What is the belt diagram from the deck to the motor for a mower?
1st, Unplug the Dryer from the Power Supply.
You will need the Exact recommended Replacement "Idler Pulley".
With the Belt Ribs Facing Toward the Dryer Drum, position the belt on the tell tale Ring Mark on the Drum letting the Belt Hang Down below the Drum.
Place The New Idler Pulley into the Slots on the Inside Dryer Bottom located near the Motor Mounted Pulley.
(Face The Idler Pulley Toward The Motor Mounted Pulley)
(Hold the Idler Pulley in place in the slots)
Take the "Hanging Belt" & run the Whole Loop "UNDER" the Idler Pulley & then
Attach the "Belt Loop" "AROUND" The Motor Mounted Pulley.
That should do it.
Put the rest of the Dryer Back Together...Done!
Good Luck,
Vinnie
Sep 20, 2014 | Dryers
The nylon or plastic belt restrainer on cabrio wed6600 dyer melted and lodged on drive belt mechanism. What is left of part appears to be a plastic or nylon closed ring drive belt retainer. How would I...
Lift the idler pulley assembly up toward the dryer drum to detach the metal tab on the assembly from the dryer base, and slide the assembly out of the open slot in the bottom of the dryer cabinet by pulling it toward you. Take the idler pulley assembly out of the dryer cabinet and dispose of the part.Slide the bottom bar of the new idler pulley assembly into the open slot in the bottom of the dryer cabinet and push down to set the tab into the hole in the dryer base to lock the assembly into place. Move the idler arm forward and place the dryer belt around the idler pulley by hand.here is the idler you need which is a pretty standard part
http://ep.yimg.com/ca/I/buyitnow64_2165_12635595
you make a loop in the belt to get it in the pulley, thats why you don't have to remove the wheel, and it comes as one complete part
Jul 04, 2011 | Dryers
I have a Kenmore Gas Dryer (model 11087471810) that threw its belt. I have the replacement belt and know how to replace that. When I opened the bottom of the dryer, I noticed the Idler pulley sitting at...
The idler pulley/tensioner fastens into two slots in the base of the dryer to the left of the motor . The belt goes around the drum then through the idler to the motor pulley ,you have to make a loop with the excess belt and feed it through the idler pulley, i normally pull the plastic pulley towards the right side of the dryer to give enough belt to go around the motor pulley then let the plastic pulley rest on the backside of the belt. do not turn the drum too much as you may pull the belt back off .
May 13, 2011 | Kenmore Dryers
Belt drum replacement
If this is a Whirlpool manufactured dryer (which inlcudes Kenmore, Roper, Estate, Kitchenaid, and Frigidaire), just follow these steps:
a. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
b. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
c. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and locate diagram H.
NOTE: It is normal for the idler pulley to come loose when there is no belt tension.
If your dryer is not manufactured by Whirlpool, or if you simply aren't sure, please post back with your model number so I can give you more accurate information. I hope you find this helpful.
Sep 01, 2009 | Dryers
Whirlpool model WGD5300SQ dryer belt is off, roller is laying loose, is there a diagram?
If the belt slipped off, this will cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To re-install, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jul 18, 2009 | Dryers
Need to install drive belt- lady kenmore dryer..loop designation
The belt probably broke first, which caused the idler pulley to come loose. This is normal. With no tension on the pulley it will commonly fall over. To re-install, follow these steps:
1. Loop the new drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jun 25, 2009 | Dryers
Idler pulley came loose and I need schematic so I can put it tog
the idler pulley fell out of its slot or it broke into pieces
if it just fell out of the slot you should take out the drum and just kind of play with it  depending on the dryer if you gave me your model i can take a look  and i dont know what kind of idler pulley you have so i am not much help AT ALL without it i;m sorry
Jun 08, 2009 | Kenmore 62622 Electric Dryer
Install a dryer belt
depends on the brand. always post brand and model #.
if it is a whirlpool or kenmore the idler pulley will be laying in the bottom of dryer. the belt should have come with instructions as to how to loop it around motor pulley and Idler.
J
Jun 10, 2008 | Dryers
Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Nov 13, 2007 | Kenmore 60172 Electric Commercial Dryer
Roper electric dryer
this should help couldnt find an actual picture so i took the time to draw a simple on in paint for you
Sep 27, 2007 | Roper REX4634KQ Electric Dryer
Whirlpool LEV4634JQ Electric Dryer Logo
188 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
