Question about Cell Phones
Hi how do i get my nokia e66 from offline to online mode please help
  • malachyfatty May 30, 2010
    GOOD EXPERT HOWEVER DID NOT SOLVE MY PROPLEM WITH SWITCHING MY NOKIA E66 FROM OFFLINE MODE TO ONLINE MODE OR EVEN GENERAL PROFILE WHEN I TRY TO CHANGE PROFILES FROM OFFLINE TO GENERAL IT SAYS PLEASE INSERT YOUR SIM EVEN THO MY SIM IS ALREADY INSERTED CORRECTLY. I HAVE ALSO TRIED USUNG ANOTHER SIM INCASE IT WAS MY SIM THAT WAS CAUSING THE PROBLEM BUT IT IS NOT IT IS THE PHONE THAT IS CAUSING THE PROBLEM AND WONT SWITCH TO ONLINE MODE. HELP!!!!???
    Genius:
  • 1,416 Answers
what you have to do from here is to configure your phone browser of your service provider
then click on your phone menu stroll to service provider click on it then click on bookmarks from here you are automatically on online model then from there you will be able to do all you which to do online and when you are through from browsing you can as well log or sing out from it in same process .
Good luck and thanks for usind fixya.
Posted on May 30, 2010
  • Oloyede Monsuru May 30, 2010
    hello,
    remember that you are told that your SIM need to be configure to your service
    provider not the phone the sim will have to be configure before if can be online as
    you have request for
    thank you.
  • Cell Phones Master
  • 4,737 Answers
Do you know how to do it on other model? like N70 or N95? Try this, go to Profile and search for "Offline" or "Offline Mode", activate the profile and you'll be offline, means there'll be no network on your phone even if it is switched on. Hope this helps. Good luck. Thanks for using FixYa.
  • 2 more comments
    I THOUGHT THIS WOULD HELP TOO BUT I HAVE TRIED IT MANY TIMES AND EVEN THO I HAVE MY SIM CARD INSERTED CORRECTLY IT SAYS PLEASE INSERT SIM CARD WHEN I TRY CHANGE PROFILES??????
  • Lebanon Raingam
    Lebanon Raingam May 30, 2010
    You should have told me this earlier :-)From your latest comment, it seems that your phone has "Insert Sim Card" problem. Would you please let me know, whether you get the error message only when you tried to change the profile or when you power on the handset? If you get the message as soon as you switch on the mobile, then it's "Insert Sim Card" problem, you'll need to go to the mobile repairing shop, if this is not the case, then please reset your phone to default settings/"Factory Restore". I hope you can do this. Here's the hint, go to settings - locate the "Factory Restore" press Ok and enter the code 12345 (if you haven't changed yet), and then Ok, your phone will automatically restart. Please let me know after this. Once again, Good luck.
    OK SO I TOOK THE SIM CARD OUT RE-INSERTED IT AND TURNED THE PHONE ON. THERE IS NO SIM ERROR MESSAGE THE ERROR MESSAGE ONLY APPEARS WHEN I TRY TO CHANGE PROFILES. P.S I HAVE ALREADY RESET MY PHONE TO FACTORY SETTINGS PREVIOUSLY IN THE HOPES THAT IT WOULD HELP BUT THIS TOO DID NOT HELP MY OFFLINE SITUATION.
  • Lebanon Raingam
    I am sorry!, from my side, i have no more solutions except flashing the set or updating the firmware. Anyway, i wish you good luck.
    Thank for Using FixYa.
E66 nokia offline mode not change what problem
being on line
its the mode your in enjoy
suggest get it fixed
Feb 16, 2012 | Nokia Cell Phones
Sir my mobile in display offline mode please solution solve
Some of the options in the available in the mobile itself.........
Aug 29, 2011 | Nokia E66 Smartphone
Nokia 6700 cant get out of offline mode???
HI,
Please follow the below given navigation path
menu-->settings-->phone settings-->offline mode
select off to remove it from offline mode.
If you have any queries Please let me know
Thank you
Jul 30, 2011 | Nokia 6700 Slide Cell Phone
My nokia e66 is showing on offline mode and if i change the profile then it didnt work. However if im inserting any other sim instead of IDEA it is working properly. So kindly let me know the soluation
Hallo! You should check your sim card in an other phone. It might be damaged. But, if your operator is 3G, this sim card wouldn't work in a GSM phone, because are different, it's not the same as GSM SIM.
May 14, 2011 | Nokia E66 Smartphone
My nokia 5800 Xpressmusic is set in offline mode how do i change it to online mode please.
Power OFF your phone. Then Power ON. While powering ON, the device will ask if you want to continue in offline mode. Select NO. This should take your phone to Online mode.
Mar 10, 2011 | Nokia 5800 XpressMusic Smartphone
My nokia e75 is in offline mode. i cannot received text and calls. how can i change my mode to online. thanks
Tap the power button once (do not hold it too long, because it will turn your phone off). Just choose any profile, and your phone will go to online mode. You can switch it anytime to offline mode, in case you want to use your phone and be unavailable at the same time, by doing the same thing - tapping the power button, and selecting offline mode/profile.
If this helps, please rate. Thank you.
Jan 17, 2011 | Nokia E75 Cell Phone
Changed nokia e66 housing.. and now offline appears with sim card inserted... tried changing profiles and setting connection to auto.. still in offline mode..
I have the same problem..i replaced the sim band and the problem still persist.. what to do ? :' and my wifi dont detect any network :' wtf?:((
Sep 20, 2010 | Nokia E66 Smartphone
Offline Mode
menu>setting>profile>SELECT GENERAL OR SILENT as you wish
Jul 11, 2010 | Nokia E66 Smartphone
Cell Phones Logo
189 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
