Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
My Briggs&Stratton 21 HP engine will run for about 5 seconds only if I pour a little gas in the carburetor. I cleaned and rebuilt the carburetor. What's the problem, please.
    Brigadier General:
  • 4,088 Answers
Fuel is not reaching the carburetor from the tank. Look for bad fuel line, or plugged fuel filter. Hope this helps!
Posted on May 30, 2010
  • drallim Jun 07, 2010
    After some on-line research, the fuel filter is a small, in-line plastic cylinder that is non-cleanable, just replace it if plugged. There is a fuel shut-off valve on or near the tank. There is a fuel pump mounted on one cylinder's valve cover and operated by pressure pulses from the crankcase. There is a solenoid valve under the carburetor that is supposed to shut off fuel to the main jet when 12 volt power is removed from it (key turned off). The solenoid commonly becomes stuck in one position or other--usually in the no-start position. You may be able to clean it, or just replace it. Hope THIS helps more!
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
I have an excell pressure washer vr2500 with a 6.5 hp Briggs and Stratton motor after pouring gas into empty gas tank see gas leaking from carburetor
YOU HAVE A FLOAT IN THE CARBURETOR THAT MAY BE STUCK THERE IS A SMALL NEEDLE VAULE THAT ALSO MAY BE STICKING YOU CAN GET A REBUILT KIT FOR THE CARBURETOR
Feb 23, 2014 | Cam Spray 25006BX 2500 PSI Cold Water Gas...
Will not start. but if I pour gas in carburetor it will. stop after the gas is burn of carburetor
Could be that the needle is stuck in carb, or else the fuel pump diaphragm is bad. Check the pump, thats what I would check first.
Jan 24, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
I have rebuilt the carburetor on a 16HP Briggs and Stratton Vagaurd. But can not get gas to engine, it runs when I pour gas in the carburator, What could be the issue.
Have you checked to make sure the float level is set correctly, or that the float isn't sticking, not allowing fuel in?
Are you pouring fuel into the top of the carby, or syphoning it in via the fuel inlet?
Jan 30, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a 14 hp vanguard that wont run because its not getting fuel,,I have replaced the lines,fuel filter and tonight replaced the pump,,all sugessted by grasshopper tech,,also replaced the tube going down...
The fuel pump works off vacuum pulses off the crankshaft. More than likely the carburetor needs to be removed and cleaned out. This is a common problem with some Briggs engines.
Oct 11, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Won't stay running
I took the carb apart and found that it needed rebuilt, I installed the new carb and fuel pump kit and it runs great again.
Apr 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,290 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
