Question about Jl Audio 500/1 Car Audio Amplifier
My jl 500.1 amp dosent play anything.
Power light comes on but no sound. Before it would play then overheat and cut off then it would cut back on then cut off again. idk the sub is mess up but idk
    Scholar:
  • 84 Answers
You have your sub wired incorrectly. your amp shouldn't get hot unless you're settings are too high or your'e sending too small of an ohm load to the amp. this would cause it to heat up and will fry your amp.
Posted on May 31, 2010
I have a jl audio 500/1. I had the amp professionally installed. The amp played for 2 days and no it has no sound but the power will come on. what could be the problem. I have new rca jacks, 4 guage power...
Go back to where you got it installed and ask them to fix it.
If you don't want to do that I would recommend going to another good car audio shop and getting them to check it out.
You can test it yourself by hooking up an iPod to it using a Headphone to RCA cable.. test at low volume first.
Dec 31, 2010 | Jl Audio 500/1 Car Audio Amplifier
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
My sound cuts out and the power light blinks consistantly about 3 times and now i have no bass and the power light comes on about every 20 seconds and then shuts off
the amp it going into protect mode because there is an internal fault with the amp. it will need to be repaired. best this to do is find a repair shop and let them handle it good luck man
Oct 24, 2009 | Jl Audio Slash v2 500/1v2 Car Audio...
JL Audio 500/1 Amplifier "Thermal" light flashing
Re-check all the connections to the speakers, The uPC monitors all the outputs and if any are taking more power than they should, the uPC shuts the amp down to protect the internal components. Don`t use tape joints alone, try to run the cable the full length without any joints. If you do have to piece the wires together, solder them and stagger the connections, in other words, make one lead shorter than the other so that if the tape does come off, the offending connection is well away from the other so they can never meet or connect to each other. Ian
Jul 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 Amp, The green power light is on but no sound!
Check to be sure you are on the correct outputs on the head unit, and be sure the outputs do not have a separate volume control.
Mar 06, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl 500/1 amplifier will not turn on
you may have burned the channel you were using..try taking the cover off the amp and checkin for burned spots or any wires that may be loose or touching within the amp.
Feb 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
I HAVE A JL AUDIO MONOBLOCK AMP 250
It indicating that the power output is too loud and possibility of speakers may get damaged if played at this volume for long periods. When the loudest sound is played the led light mightshow its loosing its brightness and dims in time with the sound level.......................sodeep
Jan 17, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL audio 500/1 produces barely any sound
have you checked the input sensor on the amp?
Oct 28, 2008 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 amp
I need the answers to the questions I posted to know the condition of the amplifier.
Jun 09, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
292 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
