Question about Kenmore 22422 Top Load Washer
Error code FL - Kenmore 22422 Top Load Washer
    Brigadier General:
  • 4,088 Answers
'FL' indicates a flood condition in the tub has been recognized. The pump is supposed to cycle on and off until the flood condition is resolved. If this condition reoccurs every time the machine is run, you may have a defective water-level switch. If the pump doesn't cycle, the pump itself may be defective or it's control board may have a defect. If you can hear the pump running, but the water level doesn't go down, there may be a plugged water line running from the outer tub to the pump or from the pump to the outside drain. It could be a slipping impeller on the pump too. Hope this helps!
Posted on May 30, 2010
Keeps getting fl error message
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
Jan 27, 2016 | Washing Machines
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
I have a kenmore elite washer and a error code fl keeps comming up and wont continue washing
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 02, 2010 | Kenmore 24032\24036 Top Load Washer
Error code fl
Flood Condition:
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$!##!
May 14, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My maytag neptune mah550bww will not start up , gives a code FL
Flood Condition: FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a backup valve or flap in the drain assembly that seems to sometimes cause problems with the FL error code. Remove this piece to see if it helps.
If this is a new installation - check that the hoses arent reversed (cold on hot and hot on cold). This will also cause the FL error.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a whrilpool calypso washer flashing the fl code
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Nov 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Getting a FL error code?
Flood Condition:
Nov 20, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Error code FL
FL means the door Locking Mechanism has failed. It will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2008 | Washing Machines
We have an FL error - all the manual says is to press stop/cancel...it's not working. How do we fix this?
Flood Condition:
Jun 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22422 Top Load Washer Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
