Question about Samsung LN40A530 40 in. LCD TV
Takes up to 20 minutes to start once the on button is selected. Seems to get progressively worse. TV is less than a year old.
  • Samsung Master
  • 1,210 Answers
You may be experincing bad capacitors. They will definitly slow the turn on time. Get this TV in, as soon as possible,bad caps can take down regulating transistors,resistors and ICs. I have not repaired this particular brand, but the symtoms are classic to almost all electronics. Thanks for asking and Good Luck!
Posted on May 30, 2010
KD-34XBR970 CRT HDTV startup problem
This is a failure in the vertical amp section. One way to troubleshoot it is to get a can of freeze spray and use it on the suspect components. The other way is to inspect all the solder joints on the amp. Last would be to check voltages on the board. Since it does change with run time, it is being affected by heat.
Mar 12, 2017 | Televison & Video
Technika 26'' lcd tv long time to warm up
the reason maybe a bad capacitor that is taking time to charge up to the nominal voltage. check for capacitors (electrolytic) in the power section (probably smps). it may appear bulgy than the others.
May 31, 2010 | Televison & Video
SOny TV starting problem
this is a pictur tube prublum. but this prublum is fixed
set filament voltage is 4.5v to > 6.0v
check G-2 voltage on crt base and cancting PF replace.
check 200v dc on crt base and replace 10uf/250v capaciter
Oct 30, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sound takes up to an hour to come on, Mitsubishi 35'' tv
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
Sep 30, 2009 | Mitsubishi CK-35308 35" TV
Kitchenaide builtin - take 20-30 pushes on start button
change the controls you can get at loocal appliance shop take model number when you go
Feb 17, 2009 | KitchenAid 34 in. KUDP01FLSS Stainless...
Dm-20 displays Chinese
To reset the settings back to English:
1. Set the DM-20 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-20 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-20 for at least 3 seconds. The menu list is displayed.
4. Click the REWIND button six times to highlight the Format menu item.
5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
6. Click the REWIND button once to highlight Start.
7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
8. Click the REWIND button once to highlight the Start menu item to continue with the format.
9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
Jan 08, 2009 | Olympus DM-20 Digital Voice Recorder
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Samsung LN40A530 40 in. LCD TV Logo
488 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
