Question about Toshiba e-STUDIO 4511 Printer
Toshiba 4511 printer with stapler...Want to staple "books" without printing and or have the thermistors to not turn on the IH coil for heat. Any way to run paper through without "heating" and just staple??
  • 1 more comment
  • wpmccollum May 30, 2010
    Not what I wanted to hear...Thanks...wayne
    hmmm, seems we have found a solution...if you have the service manuals you can hold down 0 and 8, then start the machine...the code is almost on the bottom of the list...page 2-98. Change the energy setting to 40 degrees, both the black and color settings to 120 degrees as well as the standby setting.
    This allows me to do the books without the smear...
    Thanks...wayne
    Looks like it left off the previous comments...so I will try again.
    The work around to the problem...
    Turn printer off, hold down 0 and 8, and start printer.
    On page 2-98 of the service manual you can enter 40 for energy, for both black and color you can set the temperature down from 180 degrees to 120 as well as standby. This keeps the pictures from getting too hot and will not smear, while letting the heat stay on and everything working normally...
    Thanks....wayne
  • 1,110 Answers
No way without rewriting the software for the copier. Anytime paper is run thru the machine either when copying or printing the fuser temperature is going to be raised to the preset level for the paper type being used. The only way around this as I said would be to have software/firmware written for your machine which obviously is not practical or possible. The fuser temp is adjustable in the service mode but only a small amout higher or lower than factory. You certainly can turn the heat off.
Posted on May 30, 2010
  • 2 more comments
    Is there any work around? If I print only blank pages does the IC coil still heat? Is there any way of shielding the paper from getting hot? Currently the pages I am sending through have pictures and the printer smears the ink on the next copy. If it did not heat the paper everything would work great.
    Thanks...wayne
  • Edwin Martens
    Edwin Martens May 30, 2010
    Yes the fuser still heats up even for blank copies/prints. Anytime the machine feeds and passes paper thru the machine it is going to bring the fuser up to the specified temp. There is no work around as this operation is programmed into the firmware of the machine. The only way would be to have someone re-write the firmware. This I am quite certain would be impossible to do and it would also render the machine useless as a copier/printer as the fuser would not heat up and thus not fix the toner onto the paper at all. It would just rub right off.
    Sorry I do not have better news.
    Hope you got my last comments...(the work around) ...Thanks...wayne
  • Edwin Martens
    Great. I did mention in my first post that you could turn the heat down in the service mode. But did not elaborate as you were asking if the heat could be turned off, which it can not. Hope this all works out for you and Thank You for using Fixya.
When i start my machine Toshiba e-studio 206 get Code c44
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
Thanks
Best Regards
Oct 29, 2013 | Toshiba e-Studio 205 Copier
Service call lamp
to see service call signal press cancel+8 both same time
i think its c44 error if this error its soloution below
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine. When this code not cleat 08-400 then check these all thengs..
CN455/456).
Feb 06, 2013 | Toshiba E-Studio 166 Copier, Print, Scan...
C41 in toshiba 181
CN455/456).
please vote me.
Thanks
Best Regards
Mar 14, 2012 | Toshiba e-Studio 232 Black and White...
I have a C440 error Code With my copier Toshiba E studio 352 and how can i fix the problem so that i can go ahead with my Copier for print.
switch off the macine hold down 0+8 while you switch on the machine when the macine is in test mode enter 400 and change the setting to 0 and enter it switch off the machine and wait 30 seconds then switch on the machine you should be up and running if not change the thermistors and thermo fuse
Mar 09, 2011 | Toshiba e-STUDIO 352 Black and White...
Toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
Jul 18, 2010 | Toshiba E-Studio 3511 Color Copier
I got a C440 error code sub code "7" with Toshiba E-Studio 352 copier. I tried to reset using 0/8- 400 but still the error code appears. what is the possible defective parts?
Hi how are you this is jack ...(jack_pak@hotmail.com)..
Dear follow the procedure
[C440] Fuser abnormality after abnormality judment.
CN455/456).
please vote me.
Thanks
Best Regards,
Jun 08, 2010 | Toshiba Office Equipment & Supplies
Clear a code c430 on a toshiba studio e-282
C-430: Thermistor abnormality after abnormality judgment: Abnormality of the thermistor is detected after a specified period of time has passed from power-ON (including ready state).
You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Mar 22, 2010 | Toshiba Office Equipment & Supplies
Call 4 service.. C-44
This error is a fixing unit heating fault.
Possibly a blown heater element, faulty thermistor, blown thermal fuse, or maybe a bad power supply.
You will need a service technician to fix this
Dec 08, 2009 | Toshiba E-Studio167 Copier
C 41
Try replacing the thermal fuse in the fuser. Then reset your C41 by using the "08" mode, code 89, reset to 0. If that doesn't work, replace the thermistor and do the same procedure again.
Jun 12, 2006 | Toshiba 2060 Copier
Toshiba e-STUDIO 4511 Printer Logo
43 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
