Question about Dell Latitude E6500 Laptop
How do I connect my dell laptop to my LG LCD TV
    Scholar:
  • 75 Answers
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
Posted on Jun 02, 2010
4 Suggested Answers
  • 11800 Answers
SOURCE: I connect my Dell inspiron
The setting for the resolution of the tv is set to a value that the tv doesn't support. Open the Display properties and change it to 800x600, this will work for sure. Than raise it one step at a time till it breaks.
Posted on Nov 15, 2010
  • 29 Answers
SOURCE: Connecting laptop to LCD TV
Have you tried another monitor on the VGA output? If that still doesnt work may need to set up in CONTROL PANEL>DISPLAY>SETTINGS>DISPLAY- should show another monitor fool around with that and see if you can get it to work, if so then try your tv, But ive never seen a tv with a VGA input? Maybe its me? Good luck JLS
Posted on Oct 14, 2008
  • 12 Answers
SOURCE: i want to connect my samsung NC10 laptop to my TV
has the tv got pc/vga in ? also doseur pc have s/vid out
Posted on May 18, 2009
How can I connect my laptop to my LCD TV through HDMI cable (brand:LG) (model:LF15 series) HD ready?
You'll need to make sure that your laptop & LCD TV have an HDMI port. If they both do, simply connect an HDMI cable from your laptop to your LCD TV and make sure the input on the LCD TV is set to receive A/V from the HDMI port.
Jan 11, 2013 | LG Televison & Video
How to connect laptop to LG 65LM 2500-TA
that" easy thing. first you need to check both of them --- lcd tv &laptop what kind connection have ? hdmi ? vga? rca? to find out which one. then you use one side connect to lcd tv . another side connect to laptop. & you need to sellect which one input for lcd tv. that" s it . good luck!
Sep 07, 2012 | LG 65LM6200 65 Inch 3D 1080p 120Hz Smart...
Hi i'v bought a LG LD 310 lcd tv and i want to
I tried this.. and it works perfect for the video.. but there is no audio.
Is there any specific setting to be made in TV or my laptop?
I have Dell laptop with Win7, because I dont see any option to enable audio..
Aug 01, 2011 | LG Televison & Video
I have dell studio 1537 laptop with windows vista home edition & i have recently pruchased a LG lcd 22" tv with HDMI port. I'am trying to connect but tv displays "NO SIGNAL". WHat is the...
i have connect to my laptop to the TV thru' 15-pin VGA video connector and change my graphic card setting. I have sendyou a snapshot of the setting which are similar to the laptop.moseskao_1.jpgmoseskao_0.jpgmoseskao.jpg
Dec 01, 2010 | Dell Studio 1537 Laptop
LG LCD TV HDMI port not working
Have you tried rebooting the tv with the laptop on so that it can possibly detect the laptop?
Mar 23, 2010 | LG 42LC2D 42 in. LCD HDTV
Connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
Mar 14, 2009 | LG 32LG30 32 in. LCD HDTV
Dell Inspiron 6000 to TV
On a dell laptop, the key combo FN  F8 cycles through the display options. Laptop screen, External screen, Laptop and External screen at the same time.  Try pressing the FN F8 key to get the video to display on both laptop and lcd and the same time.  If that doesn't work you can also change the settings on what the laptop does when the lid is closed.  Check the power settings in the control panel.
Dec 31, 2008 | Dell Inspiron 6000 Notebook
Invalid format when conected to laptop
Go into your control panel. Select display. There will be a picture showing 2 screens. Select the 2nd screen, and lower resolution to it's minimum. Apply and test. Slowly increase till you find what your happiest with. Worked for me using a ASUS laptop and LG60'plasma.
Jun 29, 2008 | LG 42LC2D 42 in. LCD HDTV
Pc to tv
Same problem for me too!
Dec 21, 2007 | LG 42LG30 42 in. LCD HDTV
Dell Latitude E6500 Laptop Logo
1,590 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
