Question about Whirlpool LGB6300 Gas Dryer
How do I get to the burner?
Burner not working
  • 156 Answers
THE BURNER IS INSIDE THE DRYER WHICH THE TOP NEEDS TO BE RAISED UP FROUNT REMOVED IF YOU HAVE VENT ON TOP FOR LENT SCREEN 99 % CHANCE ITS THE THERMAL FUSE WHICH IS INN THE BACK DRYER BEHIND THE PANEL WITH 8 SCREWS IT COMES OFF UNPLUG DRYER THERE A LITTLE WHITE FUSE EATHER OVERL ARE OBLONG CK IT CONTANUITY REPLACE IT SOUL FIX PROBLEM
Posted on May 30, 2010
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
Grillmaster burner no gas
Check and see if burner is blocked or injector to the burner is blocked
If you swap 1 of the buners over this will show you what is blocked
Jun 24, 2012 | Sunbeam Grill Series 760
Good Afternoon..On my Tuscany grill only 1 of the 3 burners work. looking from left to right, the left one does not work at all and the middle burner barely. No smell of gas on the 1st and very little in...
Sounds like the offending burners need to be removed, checked thoroughly for clogs and particularly the venturi valve on each burner. And while you have them out, remove the burner orifice of each burner and look for clogs.
Hope this helps you to further troubleshoot and solve the problem. Happy Grilling!!
Apr 19, 2011 | Altima Technologies AGR48PF Grill
Burner light stays on but burner does not work
Replace the burner switch, and you should be back in business. Hope this helps!
Feb 05, 2009 | GE JBP69 Electric Kitchen Range
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
JBP78W electric smoothtop small burner in dual burner not working
you call a repairman, Like I did , expect to pay 150.00 or more as the small burner and large one are in the same ceramic holder
Oct 17, 2017 | GE Spectra JBP78 Electric Kitchen Range
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Nov 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE XL 44
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Burner works intermittently
You have either a bad burner or a bad control for same, or bad connections.
With power removed use a pair of pliers to crimp the connections (after cleaning the ones on burner) going to the burner.
Jun 17, 2017 | Kenmore 91112 / 91114 / 91117 Electric...
Whirlpool LGB6300 Gas Dryer Logo
49 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
