Question about Craftsman Gas Mini - Tiller/Edger
I have a sears craftsman 580 751 651 and after a few seconds running the engine cuts out as if the off switch is turned on please can anybody help with this problem thanks Dave.
  • Craftsman Master
  • 7,482 Answers
Hi Dave
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 30, 2010
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Sears Craftsman 1/3HP garage door opener problem
If motor continues to run but no chain action check for missing chain tooth or cam gear worn.
Sep 22, 2017 | Sears Craftsman LiftMaster Chamberlain...
I have a 42in cut 19.5hp automatic trans craftsman when i press the clutch/brake to start then release to drive it cuts off also if i try to engage the blades it cuts off but if i lock the clutch/brake it...
The problem is in the seat safety switch or associated wiring. Lift the seat, find the switch, and take a look for a connector that is off, a broken wire, or a loose or broken mounting for the switch. If all that seems ok, remove the switch and put tape across the plunger so it is activated. Run the mower and see if the problem is solved. If not, replace the switch - it's not expensive. Parts are available from Sears online or at their stores. You'll need the model number of your tractor. Good luck! Please rate my solution if helpful.
Aug 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I try to start my craftsman lawn tractor.when I turn the key the flywheel turns about 1/4 turn.i waitsame thing.i wait 5 minutes it will turn but will not crank. I wait a few more minutes and it...
if the engine is a briggs and strattion the valves have to be re adj to 4-6 thou intake 5-7 on the exaust i am a sears teck i see that problem quite often
Jul 03, 2010 | Garden
I have an 18hp 42inch cut Sears Craftsman, it will
You might want to checked your fuel line coming from the tank,sometime it will collaspe inside the line and not allow enough gas to get to the engine.
May 15, 2010 | Garden
Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Aug 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Mower starts but when you take your foot off the clutch it stops
sound like the seat saftey switch under seat you can either unplug it and see if that works or jumper the wires with a piece of wire if either works replace switch
Mar 24, 2009 | Craftsman Laser Level - Sears 180 Degree...
Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Gas Mini - Tiller/Edger Logo
250 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
