Question about Mtd Garden
Runs fine until I engage the PTO and am on a slight incline.Starts to spit and sputter and cut off. Checked Plug Gap, Magneto Gap. Worked fine last summer. All I did this time was replace the blades. Replaced old gas with new gas. No matter how I adjust the Carb to make it run fine and idle fine, as soon as I either get in some tall grass or am on an incline, it dies. The Briggs and Stratton engine, model 282H07-0334-E1, has a wiring harness with two leads attached to the bottom of the bowl on the carb. Disconnecting that results in an immediate shutdown. Had NO problems with it last summer and began this problem when started up this year.
    New Friend:
  • 16 Answers
Check your fuel lines for clogging if it ran fine last year means you have a clogged fuel line somewhere or the carb itself is stopped up disassemble the carb and do a visual inspection also use B12 chemtool carb cleaner use both the spray and the fuel cleaner treatment i know for sure your problem is related to ethanol fuel hope this helps good luck and always run your equipment completely out of fuel for long term storage or between seasons
Posted on Apr 07, 2017
  • 36 Answers
SOURCE: 2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Posted on Nov 29, 2008
  • 91 Answers
SOURCE: 5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Posted on Mar 30, 2009
  • 661 Answers
SOURCE: starts runs min. or two then stops....
Go to then click customer care, then click manuals and parts. Type in model no. and download the owners manual. This should get you the spark and flywheel gap. Probably still something in the carb. Some orifices are very hard to find and to clean but they must be clean. Also check for dirt dopper nest in the muffler.
Posted on Apr 06, 2009
  • 226 Answers
SOURCE: briggs and stratton engine smoking
if your oil level is to high it will do this. i would drain and refill the oil to oem specs slowly as not to overfill so it doesn't blow over the top of the piston.hope this helps
Posted on Jun 25, 2009
  • 14 Answers
SOURCE: Bolens 4.5 Briggs and Stratton: I prime the carb
Be sure the fuel is fresh....meaning, fresh from the gas station. IF that doesn't fix it, replace the carb.
Posted on Oct 08, 2009
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
I have a ariens zoom 1540 mower it runs fine but the blades wont engage to mow. It worked when i put away after last mowing and 2 days later it doesnt. Ive checked the wires off pto switch and they seem...
You've checked the wiring to the PTO and it looks OK. Does the PTO engage when the switch is thrown? Do you have a multi meter , so you can trace the voltage to the switch, from the switch to the PTO. You also should check the safety switch (s) which will prevent the PTO from engaging if there is a faulty switch. And it could simply be a fuse that has blown.
Jun 20, 2014 | Garden
John Deere LX173 pto will not engage. Wet recently
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
Oct 24, 2012 | John Deere Garden
The 12.5 murray 38 in runs fine until i engage the blades,while engaged the mower runs fine for about five seconds then starts to spit and sputter.once i disengage the blades it runs smoothly again
The problem is in the carb. First try using some bottled fuel system cleaner at a heavier dose than for a car, but be aware that too much may damage the carb. Then run the fuel out and fill with fresh and try again. When you engage blades and it sputters try to throttle down until it runs smooth and then slowly bring engine back up to mowing speed. You should be able bring it up and mow. Run out the fuel tank. If unable to do this trick and get the fuel system cleaner through you will need to have the carb. taken apart and cleaned thoroughly.
Jul 07, 2011 | Garden
Engine does not start. Starter & solenoid work fine. Checked air filter, fuel filter, fuel level, level in choke position. Plug is kind of flooded. Increased plug gap slightly. There is no spark....
Most small engines use a flywheel with a magnet embedded in it and an ignition coil with a core that sits a few thousandths away from the flywheel. Ignition coils are common failures probably because they come from our wonderful Chinese friends. They have demolished all US manufacturers. If you replace the coil, use some gauge to measure the gap between coil core and the flywheel magnet surface before removing the old coil. Otherwise you may spend a little time using trial & error to get the engine running again.
If your engine is a Briggs and Stratton, you can find very complete maintenance downloadable information on their website. This will pertain to the engine only, not the mower.
Dunno about Tecumseh, haven't had much need for service info on those.
Jun 30, 2011 | Cub Cadet Lawn Mower Electric PTO Clutch...
When my dirtbike is finally warmed up it begins to spit and sputter. I wrecked and bent my head pipe slightly. Would this cause my bike to want to die? When it is cold it runs just fine.
Hi, you dont say what this bike is, is it. Two or four stroke engine,
On a 2stroke this type of problem could simply be carbon jumping around between the gap on the plug,
Or a crankshaft oil seal leaking,
Feb 23, 2011 | kawasaki KX 250 Motorcycles
97 nissan altima just started runs fine when cold when it gets warn it starts to spit and sputters giving it gas wont help, i checked plugs and there fine checked cap and rotor and they look good i even...
Sounds like plugged catalytic converter, Disconnect exhaust in front of Cat. and see what happens. Check to see if you are losing fluid from radiator.
Jan 11, 2010 | 1997 Nissan.5 Altima
Spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
May 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
64 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
