Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool sxs with ice/water dispenser, makes ice, stuff melting inside, though. Removed back pannel in freezer, coils are clean, coil fan running fine. set on coldest setting, it is 62 degrees right now.
    President:
  • 547 Answers
Is the fridge side cooling properly, or is it warm too?
If the fridge side is warm, then you're losing coolant, and most likely have a leak in the compressor or coils.
If the fridge side is cold and the problem is isolated to the freezer, then the problem is with either the circulating fan or the cold control for the freezer. The circulating fan is inside the unit, behind a plastic panel on the back wall. With the fridge off, you should be able to move the fan blades freely (virtually no friction) With the fridge on, they should spin up within 5 minutes of plugging the fridge in.
If the fan is working properly, then the next thing to check is the thermostat. You can put a multimeter on the output of the thermostat, and verify that it changes (from voltage to no-voltage or from no-voltage to voltage) when you adjust the freezer thermostat, but I'm not aware of any diagnostic beyond that. They're cheap enough and easy enough to replace though.
Posted on May 30, 2010
  • 1 more comment
  • brindy2 May 30, 2010
    Thanks for the reply.
    The fridge side is warm as well.
    The circulating fan is running well, too.
    I'll try to check the thermostat, not sure how/where this is...
    Thanks again.
  • Rob C May 31, 2010
    If the compressor runs, then the thermostat is doing its job -- it's saying "I'm too warm, run the compressor"
    The fact that it doesn't cool either side (fridge or freezer) means that the coolant isn't working, either because the compressor is burned out or because you've lost coolant. Since you didn't say anything about the compressor sounding bad, the most likely thing is that you've got a coolant leak. Sometimes these are reparable, sometimes they're not and the cost of the fix is more than a new fridge.
    I wish I had better news for you, but I would recommend that you contact a local repair tech at this point to see if:
    #1 - am I right about what's broken
    #2 - does it make economic sense to fix it or replace it
  • brindy2 May 31, 2010
    I was able to get a local handyman to come over. He suspected the PTRC-Relay or the capacitor. He put a new PTRC-relay and capacitor in and it took off running. Apparently, the compressor was not running, even though the fan underneath was running. It seems to be cooling. We'll put the frozen stuff back in tomorrow.
    Thanks for your help.
    Bill
I have a Skybox by Maytag - it has been running great for 6 years. Now it is leaking water everywhere. Not sure where it is coming from. I opened the back pannel and there is water inside on the bottom...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 24, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
Ice maker.....placed glass and push button to dispense ice and nothing happens. No sound as though ice is trying to dispense. Open freezer, plenty of ice in bin and cleaned out freezer and removed all ice....
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 17, 2011 | Refrigerators
Ice maker not producing any ice water dispensing
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 30, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Not producing ice from ice maker
Leo Ponder
imufo2
Jul 28, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool side by side it does not have the water dispenser in the door and does not have an ice maker. Found out today that the freezer was slowly thawing and that the fridge is not cooling. The...
I'm Leo
If this was helpful please rate me
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
Please click for article
Jul 26, 2011 | Whirlpool ED5VHGXM Side by Side...
I HAVE A WHIRLPOOL SIDE X SIDE MODLE # ED5RHEXNL 03 MAKES ICE BUT NO WATER FLOW.
There is a double or triple water valve in your fridge. check continuity on the water dispenser valve coil in the back of the fridge (small terminals, thicker tubing, green coil). Replace valve (part number 4389177) if no continuity. If ok, check if there's line voltage (110-120V) to that coil when the dispenser actuator is pressed. If there is power and there is continuity on that coil - water line is frozen inside the freezer door. Turn off and defrost the refrigerator for full 24 hours. put towels under the freezer door to catch melting ice formed from condensation inside the door. repeat every year or as necessary.
If no power to the water valve coil - check the switch actuated by the water lever in the dispenser assembly. Replace if faulty. Regular microswitch is ok, but if you want the OEM part number, there it is: 2162361
Vlad
First Choice Appliance
Apr 16, 2010 | Whirlpool GS6NBEXR Side by Side...
Not cooling
Roy,
Are the evaporator coils in the freezer frozen up?
The evaporator is located behind the cover in the back of the freezer.
If so this may be a defrost issue.
The adaptive defrost timer may have failed.
This is located in the ref. side inside the front control pannel.
If not then you may have a freon leak.
This would have to be repaired by a qualified technician.
Jan 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Heat strip is to hot on freezer door frame whirlpool frige sxs.....
Two things can cause this:
1. Dirty coils.
2. Bad condensor fan motor (this cools the coils). The fan motor can be accessed from the back by removing the lower panel.
Dec 03, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Jun 26, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    Whirlpool GS6NBEXR Side by Side Refrigerator Logo
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
