Question about Boss BV9560 Car Video Player
When going into the general setup, I click on system set and it requires a password to enter. However, I did not set up a password therefore I do not know what the password is. Is there any way I could reset it?
  • Shahid Electronics
    Shahid Electronics May 30, 2010
    Check documents supplied with unit, you will find password there as it is security feature of unit or contact dealer to whom you purchased it to supply you password.
HI,
the BV9560B use 2 passwords.
one for the bluetooth and children restrictions "0000"
and the master setup, for touch and others "8888"
but be careful with the touch adjust... i have serius problems with this settings
see you
Posted on Nov 17, 2010
  • Jorge May 14, 2012
    Hi everyone!
    I have a boss BV8965B, my baby droop the faceplate and crack the touch digitizer. I replaced it very carefull but when i turn off the player the touch function wont work..If necessary calibrate or adjust the new touch panel?? How i can do that?? Please help me!!
My screen has froze how can I use it again on a bv9560b....I cannot use the th touch screen
Posted on Mar 26, 2011
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
Tip
How to setup the D-Link Dir-615 Wireless Router on the Internet 1. You will need...
1. You will need to connect your Cable or DSL modem to the Internet port on your router.
2. Connect your computer to any of the 4 LAN ports
3. Next you will want to insert the "Quick Router Setup Wizard CD" in to your CD-ROM drive. This will take you through the automated steps of setting up your router to work with your modem. Note if you have a DSL modem that uses a PPPoE connection software program you will want to uninstall it from the computer before you continue. Also you will need make sure you know the user name and password because you will need to enter it as a part of the setup for the router.
4. When the setup wizard opens you will want to click on "Install Router" in the upper left hand corner.
5. Click on the option for "Setup Wizard" to use the setup wizard.
6. Click "Launch Internet Connection Setup Wizard" to start to setup your LAN settings
7. Click "Next" to continue.
8. At this point you will be asked to create a new password. After you entered a new password click "Next".
Note it is important to setup a password at this point especially if you plan to setup a wireless network so no one will be able to gain access to your router settings.
9. Click on the drop down menu to select your time zone and click "Next"
10. You will need to select the type on Internet connection you have and click "Next"
11. Here are the different step you need to go through depending on the option you selected above.
DHCP
- If you selected DHCP then you might need to enter the MAC address of the computer that was last connected directly to your modem. If this is the computer you are currently connected to then just click on the "Clone Your PC's MAC Address and then click "Next"
Note you may need to enter a host name if this is required of your ISP.
PPPoE
- This is where you will need to enter your PPPoE user name and password.
Note as a reminder if you have not uninstalled the PPPoE software from your computer because it is not needed any more.
PPTP
- This is where you will need to enter your PPTP user name and password.
L2TP
- This is where you will need to enter your L2TP user name and password.
Static
- You will need to enter the network settings provided by your ISP
After entering the required information click "Next"
12. Click on "Connect" to save your settings. At this point your router should be rebooting. After it is done rebooting then click "Continue". Next you will need to wait 1 to 2 minutes while the router connects to the Internet.
Now you should be connected to the Internet. If you are not connected you may need to review you settings. Also you may try unplugging the power from your modem and the router. Then next plug the modem back in and let it run for about 30 second and then plug the router back in. If you still have trouble you may want to contact your ISP to make sure you have your settings right.
on Apr 26, 2010 | D-Link DIR-615 Wireless Router
How to change password for wifi
1 - Enter your router's address in a browser window. In the URL field, enter one of the following numbers based on the model of wireless router you use:
  • 192.168.2.1: Belkin, Microsoft, and SMC:
  • 192.168.0.1: Qwest (AKA CenturyLink), Netgear, DLink, Senao, Trendnet
  • 10.0.1.1: Apple
  • If you don't see your router listed here, search on Google for your router name and include "default IP address" to find the correct information.
  • On a PC, open the command prompt (click on Start > Run/Search for "cmd") and enter ipconfig. Look for the Default Gateway line, and try that number.
  • On a Macintosh, open Network (System Preferences..., Network) and look for Router:<number>. This is your router's IP address.
  • Enter your router's user name and password, if requested. Not all routers require that, but if yours does, it should be listed with the documentation. If your router does require a password, but you didn't set one, the default password is usually "admin." You can usually leave the username field blank.
Go to your settings page. It may be called "settings," or "wireless setup," "preferences," or similar name.
Locate the password setting. It may be a field or tab named "password," "wireless security," "security key," "passphrase," etc. If the field is directly editable, enter your new password. Otherwise, click the tab or button to access the password field.
Enter a new password. If there's a second password field, re-enter your password exactly the same way, capitalizations and all. If not, just enter the password once, but be sure to enter it carefully, and make note of it until you have it memorized.
  • When finished, click "OK," "Apply," "Submit," "Save," or whatever button finishes the process.
  • Close your browser window: your password is changed.
Feb 02, 2014 | Computers & Internet
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Starting with the computer fully off, turn it on by pressing and releasing the power button.
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key.
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Dec 12, 2010 | YouTube Videos
How to do a PPPoE connection?
You have not mentioned OS you are using, i am assuming that you have windows xp or later. Go to properties of my network places and click on create a new connection > Connect to Internet > connect to broadband that requires user name and password .. follow next steps as appears it will install PPPoe protocol and will make a connection also
Jun 26, 2010 | D-Link DFE-530TX+ Fast Ethernet PCI...
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
Mar 02, 2010 | Computers & Internet
Transfer papers filed with Dell. They gave me a password ZRBFRWSE, WHICH DIDNT WORK.
You didn't post the model system, but generally Dell master passwords are all entered lowercase (zrbfrwse) hold the CTRL key and press enter.
The master password is generated based on the code displayed prompting for the password. Most the systems have options for both BIOS and HDD passwords, it is possible that both BIOS and HDD passwords were setup, the each require a different password.
Oct 23, 2009 | Dell Computers & Internet
Xerox 7328, error 018-543 Shared name error in server
Prerequisites:
  • The printer must be connected to the network.
  • The IP address of the printer is required.
  • The HTTP option must be enabled on the printer. To obtain the IP address or to confirm if the HTTP option is enabled, print a Configuration Report. See the Related Items below for additional information.
  • A user account for the scanner must be created (account needs full control access rights).
  • A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
  • The Hostname of the workstation must be known.
Scan to File is set up in several steps:
  1. The first step is to make sure the scanning service is enabled on the printer.
  2. The second step is to set up the scan file repository.
  3. The third step is to create any necessary templates.
  4. The final step is to configure the template with the required settings.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary.
  1. Make sure the SMB port is enabled. Print a Configuration Report to verify this setting. See the Related Items below.
  2. Open an Internet browser window.
  3. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  4. If prompted, enter the username and password in the fields provided, and then click [OK].
    NOTE: The default username is "11111". The default password is "x-admin" and must be entered in lower case letters. If the username or password has been modified or forgotten, contact your System Administrator.
  5. Click on the [Properties] tab. The Properties options will be displayed.
  6. Click on the [+] next to Services on the left side of the window to expand the options.
  7. Click on the [+] next to Network Scanning.
  8. Click on [File Repository Setup]. The File Repository Setup window will be displayed.
  9. Click on [Edit] in the Default File Repository section. The File Destination screen will be displayed.
    NOTE: A maximum of five file repositories may be configured. Generally, just the default repository is configured for scan to file.
  10. Select [SMB] from the Protocol menu.
  11. Enter a descriptive name in the Friendly Name field.
  12. Enter the IP address or Hostname of the computer where scanning will be setup in the Hostname / IP Address & Port field.
    NOTE: The default SMB port is 139. Generally this port number does not change.
  13. Enter the Share name in the Share field.
  14. If necessary, enter the scan path in the Document Path field.
  15. Click on the [Prompt at User Interface] or [System] radio button from the Login Credentials to Access the Destination section.
  16. Enter the scan user name in the Login Name field.
  17. Enter the scan user password in the Password and Retype Password fields.
  18. Click on [Apply]. A “Settings have been changed” message will be displayed.
  19. Click on [Reboot Machine]. A "Do you want to reboot?" message will be displayed.
  20. Click [OK].
  21. Close the browser window.
  22. Test scan to file using the default template. See the Related Items below.
  23. If necessary, create scan templates.
Dec 16, 2008 | Xerox WorkCentre M128 Copier
Connection to my computer of hp photosmart c6300 via belkin adsl2router
2Wire 2700HG-B Setup
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE beoswer.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
Oct 30, 2008 | 2wire 2700HG-B Router (2700HGB)
Setting up Wireless Security ? BEFW11S4
Securing your wireless network is a simple process, which generally does not require a lot of time. Please follow these instructions to secure your wireless network. Accessing the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 2. When "Internet Explorer" opens type http://192.168.1.1into the "Address" bar and click on Go 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK Setup Page Security Options When you arrive at the Setup page, you'll see the bulk of your wireless security features. There are three things you're going to want to set on this page: 1. SSID a) Delete linksys from the "SSID" field b) Input your own unique SSID. We general recommend something easy to remember, but secure enough to where people would not be able to guess it easily. Sometimes your best bet is to use your last name and add some numbers. a) Click Apply then Continue 1. SSID Broadcast (Firmware 1.42.7 and above only) a) Click No on the Allow "Broadcast" SSID to associate? b) Click Apply then Continue 2. WEP a) Click Mandatory for the "WEP" Option b) Click the WEP Key Settings button c) When the "Wep Key Settings" Window appears, change the option from 64 to 128* NOTE: 128 bit WEP may not work on non-Linksys products due to its lack of an IEEE standard d) Enter a passphrase** that is different from the SSID. Try to make it alphanumeric; instead of password, use password5532. Once the key has been Generated copy the key into a notepad document and copy that file onto a floppy. **NOTE: The passphrase will not work with non-Linksys products, so you will need to use the passphrase that you copied onto floppy. e) Click Apply then Continue f) Close the window g) Click Apply then Continue on the setup page. Setting up Station MAC Filter The Station MAC Filter option is a very good security feature that has been added to Firmware 1.42.7 and above. This option denies all wireless clients except those listed. To implement this feature please follow these instructions: 1. From the "Setup" page, click Advanced 2. When the "Filters" page opens, click on the Wireless tab 3. Make sure all wireless computers are setup to the router, and are currently able to access the internet. Once this is done, click on the Active MAC Table button. 4. Move the "Wireless Active MAC Table" window and click on Edit MAC Filter Settings on the main window. 5. When the "Wireless Group MAC Table" opens, go to the task bar and click on the Wireless Active MAC Table so that window appears. 6. With the two windows side by side enter the MAC Addresses from the "Wireless Active MAC Table" window into the Wireless Group MAC Table. - NOTE: When you enter the MAC Addresses do not include the dashes, and do not click "Filter" 7. Click Apply then Continue in the "Wireless Group MAC Table" window. 8. Close the "Wireless Group MAC Table" window and the "Wireless Active MAC Table" window 9. On the Main window Enable the Station MAC Filter setting.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Boss BV9560 Car Video Player Logo
696 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
