Question about kawasaki Full Suspension Mountain Bike Men
How to adjust carb on kawasaki klx 125
Bike is hard to start and slow to warm up. choke must be left on partially for bike to run
  • 41 Answers
SOURCE: Kawasaki KLX 400 dirt bike
hello, check to see if u have fire at the plug. If no fire, then check wires at the new cover
Posted on Nov 25, 2008
  • 12 Answers
SOURCE: starting 2007 kawasaki klx 250
• The first thing to do with ANY engine that has sat for any longer than a couple of months is to dump ALL the fuel in the tank and carb(s). ALL OF IT !! You'll want to refill with some high priced fuel that has fuel system cleaners (Like Chevron with Techron) not becasue you need high-test fuel, but because you need the cleaners. It's ether that or disassemble the carbs and clean out jets you can't find much less see. Your choice. The carb kits alone will cost you about $50 so a tank of high-test is looking pretty good, huh?
• Now the fact that you tried to crank the engine with old fuel has fouled the sparkplugs. All of them. Go buy all new sparkplugs.
• If your bike has a vacuum fuel valve, then you'll also need to set the valve to "Prime".
Posted on Mar 21, 2009
  • 3567 Answers
SOURCE: broke carb
I don't quite understand what you and I'm not sure that I want to know. :)
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part and/or the notation "Not Available" is in the description, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Can I get a “very helpful” rating on this answer?
Posted on Aug 29, 2009
bazzz7071
  • 342 Answers
SOURCE: can you adjust the seat height on my kawasaki 125?
No what you can do is take it to some one who does custom seats and discuss having it re done with thicker foam piece raising it to your comfort.
Posted on Jun 01, 2010
  • 21 Answers
SOURCE: 2003 KLX 125: how fast do 2003 kawasaki 125 KLX go...
Should do around 55mph at wot in 5th gear with an averge sized person on the bike.
Posted on Jul 20, 2010
Bought 2004 Kawasaki klx 125 and takes 20-30 kicks to start with choke on and even more when cold. Won't run right until motor warms up n takes a while for it to warm up. Runs fine after it does but it's...
Be certain the battery is in good condition. Install a new spark plug. Clean the carb and air filter. Use the throttle sparingly. The carb has a power valve that gives an extra shot of gas each time the throttle is twisted. Too many twists and the engine floods out. Please rate my answer. Thanks!
Mar 25, 2011 | 2004 kawasaki KLX 125
I have a 2008 Kawasaki klx 125 I just bought used which takes 20-30 kicks with the choke on to start and if it is cold outside even more. Then the choke has to stay on for a minute until the motor gets...
Well - usually something like this would make me suspect the compression and timing first then the jetting in the carb. You might want to do a quick compression check although I do not know what the pressure should be for your bike. I would suspect at least 165PSI. You could have bought a bike that was run without an air filter or something like that.
I would also check the simple stuff - clean the air filter, drain the float bowl and tank and replace with fresh fuel (especially if your fuel is diluted with Ethenol !) and maybe even replace the spark plug.
If all this checks out OK and you still have the same thing going on, you might need to alter the low speed jetting (pilot jet).
Scott
KLX 100 will stay running with choke fully in
have you checked the fule flow from the fule tank?
you may need to strip the carb down to give it a realy good clean out too this bike is just not getting any fule to it
Jul 06, 2010 | 2007 kawasaki KLX 250
What is the choke position on 2004 klx 125, up or down
Down is choke "ON" and up is choke "OFF". Had same question and found on another site. Made carb adjusrment much easier after cleaning. Bike was new to me and runs great now.
Jun 05, 2010 | 2004 kawasaki KLX 125 L
Won't idle without choke, turn throttle boggs out
have u checked the float hight on the carburator? also make sure ur choke curcuit i clean and free of dirt
Apr 13, 2010 | 2005 kawasaki KLX 125
2004 klx 125l bike ideling
How long has the bike been sitting? The gas may be bad or the carb might need to be cleaned out or choke may be sticking.
Feb 06, 2010 | 2004 kawasaki KLX 125
2004 125 klx kawasaki
The jet valve in the carb may be blocked. Or your carb dismantling job was not as good.
Oct 29, 2009 | 2004 kawasaki KLX 125 L
My KLX 125 2004 will turn over but wont idle
Might check: Air filter, choke malfuntion or sticking, dirty carb (idle circuit), valve adjustment, and sometimes a weak spark (cap, plug, wire). Could need a new top end (check compression after adjusting valves) or a vacuum leak in the intake manifold (cracks, petcock line off...not sure if this model uses a petcock vacuum shut off). Good luck.
Jun 25, 2009 | 2004 kawasaki KLX 125
I have a 2005 klx 125 it starts and runs fine THEN BOGS OUT AT
when riding try pulling choke u p and see what happens
Jun 04, 2009 | 2003 kawasaki KLX 125
2004 Klx 125 only runs with choke on. Barely starts
Mixture is off on the Carb, try backing the mixture screw out a quarter turn. Better/ Worse?
Apr 14, 2009 | 2004 kawasaki KLX 125 L
kawasaki Full Suspension Mountain Bike Men Logo
326 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
