Question about Samsung TV Remote Control
Remote control of my TV is not as deconfigured and configure remote control of my TV is not as deconfigured and configure
Toshiba codes
Hi Ian,
The number or code that corresponds with your tv remote is "0".
Kindly click the link below to help you configure the remote control on talktalk.
Hope this one helps you.
Can use my TalkTalk TV remote control with my TV TalkTalk Help
Feb 06, 2014 | Televison & Video
How to reset a Panasonic VIERA TX-32LX60F TV settings?
To reset the TV into factory settings, you have to enter its service mode. http://electronicshelponline.blogspot.com/ Check this link, and pull up previous posts to get more details about how to enter service mode.
Jun 09, 2013 | Panasonic Televison & Video
No codes on the remote control to configure the self focus
Codes for Samsung are: 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Sep 18, 2012 | Televison & Video
Philips 30HF9975/12Z
You need to configure the universal remote with your TV. You need to go through the instruction manual of the universal remote to understand how to configure the same.
Jan 17, 2012 | Televison & Video
HOW can I search and install a station on my tv using Grundig rc-7-1 universal remote control?
turn on your tv. make sure youre on tv! then press set and on keep it in 4 sec to the led flash red. it will now search, when its done your tv will go off press any key and your tv will pe configured.
Jan 26, 2011 | Universal Remote Control GE174Universal...
I have a universal remote 360201 and I need the tv codes for it
Hello.
Without knowing the brand name of your universal remote the best advice I can offer is the following website:
http://www.tvcodes.com/
All the best.
Nov 21, 2010 | Universal Remote Control Remote Control
Will not change the channelwhat is the matter
It sounds like your remote is not completely configured for your television. To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
I hope that helps.
Dec 20, 2009 | One For All URC-3021 Remote Control
I have 3 TV all the same, Panasonic, how do I set my remote to control all three with the one Logitech Harmony remote?
If they are exactly the same model and your component setup is the same as well (for example, you have exactly the same TVs and they each have the same DVD player as well, and the inputs-outputs have all been configured the same way), then the 'Watch TV' activity you set up will successfully control all of the setups in each room. But, let's say that you have the same TV in each room, but in one situation you have a connected DVD player and in another you have a home theatre and still the other is only the TV by itself with no additional devices. In this case, you would set up 3 different Activites and call them 'Watch TV 1", "Watch TV 2", etc. Each activity would be configured to use the same make & model television, but would also include the devices that were unique to each room's configuration. Hope this helps!
Sep 09, 2009 | Logitech Harmony 880 LCD Remote Control
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Samsung TV Remote Control Logo
Jerry Greenberg
Jerry Greenberg
