Question about Whirlpool DU1055XTS Built-in Dishwasher
Will not turn on
Control panel lights blinking
  • 523 Answers
It is an air code meaning the heater is bad but most likely not look under unit for a book it will tell you how to get it out of it
Posted on May 30, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
One of my ac's light is blinking and wont turn on. Is not the control batteries, what could it be?
Laptop Won't Turn on, Blinking lights - HP Support Forum ...
h30434.www3.hp.com > Laptop & Notebook > Boot
Solved: Hello My laptop is an HP pavillion dv6z-1100, its running a 64 bit version of windows 7 ... Message 1 of 38 (164,169 Views) ... Upon attempting to turn it back on (while being plugged into the ac adapter) the computer would power up, ...
Air conditioner light blinks - Discussion on Topix
www.topix.com > Chevrolet Malibu
Jul 11, 2006 - my 2001 Malibu has this problem, blinking A/C light. ... On the control panel for the air conditioner, the ac button(the one with the little green light) blinks on ... The ac will turn itself back to outside air after it has been running on ... 2002 A\C Blinking
May 14, 2007
2003 Toyota Camry A/C button flashing
Apr 10, 2007
More results from www.topix.com
Dec 25, 2015 | Computers & Internet
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
BLinking panel lights will not turn off
Specifically what lights are blinking? Do you have the child-lock (control-lock) turned on?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 14, 2014 | Jenn-Air Dishwashers
Television does not show picture, does not turn off, does not respond to controls. on-light turns on, but not much else. NEED HELP!!!
Does the power indicator light flash or blink? If it does, count the number of blinks and then Google your make and model with the words blink codes at the end. This will take you to sites that will tell you what the blink code means.
Sep 04, 2011 | Televison & Video
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Change water pad but change water panel light is on
Turn the control knob to the
“Test/Reset” position until the “Change
Water Panel” light blinks to reset the
water panel change indicator timer.
(Blower must be operating and furnace
calling for heat.) Be sure to turn the
control knob back to the prior setting when finished
Oct 27, 2009 | Aprilaire 700 Humidifier
Can't make copies
I had the same problem just yesterday. Turn off the printer for 10 seconds. Then turn back on. Turn back off again and unplug from the electrical outlet. Open the control panel and tilt it toward you. Close the control panel, plug machine back into the outlet and turn back on. I did this and it solved my problem.
Sep 10, 2008 | HP Laserjet M1319F Laser Multifunction...
Whirlpool DU1055XTS Built-in Dishwasher Logo
99 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
