Question about Sony DAV-HDX500 System
Unlock code for multi region discs on this player
  • 10,421 Answers
I have a Toshiba DVD player SD290EKB and would like to play Region 2 discs. How can I change region.
Toshiba SD290EKB
REGION UNLOCK CODE
When i bought this it said multi-region but its not. To unlock it to play all regions turn on the dvd player open the disc tray and then enter 98790. It will now change to region 0 making it able to watch all regions.
Hope that helps.
Nov 17, 2010 | Toshiba Televison & Video
Region free code
Can you please give the make and model no. of the unit
Jun 14, 2008 | Craig 731398407019 Portable DVD Player
PANASONIC SC-BT200 UNLOCK REGION CODE
Google for "Panasonic SC-BT200 Region Free
Also see
"http://www.avforums.com/forums/blu-ray-players/885440-blu-ray-player-multi-region-hex-codes.html"
Some Blu-Ray players will need a hardware mod to be region free.
Feb 05, 2010 | Panasonic SC-BT200 Home Theater Systems....
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Unlock codes to multi format
My region 4 SD-890KY came with a region free upgrade disc. I live in Australia. The disk might work for region 4 players only.
Jun 26, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
How to unlocked region code
XD-DV480 Multi-Region: Converting the player to an alternative region:
  • Supply power to the unit and power on from standby mode via the remote
  • Wait until No Disc is indicated on the fascia
  • Now press Pause followed by 3, 4, 2, 2, 9 and then 2
  • The display should now read CODE
  • Now press 0, 0 for region free or 0 then 1 for region one, 2 for region two, and so on (Note: RCE discs will require specific region set)
If the above modification fails to work then the alternative method below may work:-
  • Connect the DVD player
  • Use the Remote Control to turn power on
  • Wait until No Disc appears
  • Press Pause and type the following code, 8, 9, 2, 6, the display will show "CODE__"
  • Within 5 seconds press 00 for all regions
  • Press Pause and Power
This should work for you.
May 07, 2007 | Aiwa XD-DV480 DVD Player
Sony DAV-HDX500 System Logo
181 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
