Question about Vacuums
Need parts for everstar garage vacuum Filter and dust bag.
shaggyrat
  • 1224 Answers
SOURCE: Drywall Dust Damaging to Vacuum?
it shouldnt hurt it as long as you keep the vacuum clean after use when you leave the dust sit in on it it hardens but as soon as done vacuum the motor and blow it out with compressed air this shall give you a longer life
Posted on May 16, 2008
VacuumRepair
  • 438 Answers
SOURCE: Kirby G4 Vacuum "BOOT"?
Greetings from GoVacuum,
The bottom part of the bag, which you referred to as a "Boot" is actually called a Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S. The part is only available to purchase with the fill tube assembly, this is the part that the disposable paper bag connects to inside the cloth outer bag.
Kirby has redesigned this fill tube, as the original design sometimes would cause the inner fill tube to crack. The Mini Em-Tor Fill Tube Assembly, part 199493S comes already assembled with the "boot" at the bottom, and the vacuum bag collar (the part the bag actually attaches to) at the top of it. You will need to remove the cloth outer bag from your old part, and put it onto the new "Boot". The cloth bag connects the "boot" with a special zip tie, which is Kirby Vacuum Bag Clamp. Kirby Part # 196599S. Where it is possible to remove the bag clamp without breaking it, I will warn you that this is no easy task. Spare yourself the aggravation of having to try and remove the clamp, and just cut the bag clamp with a knife or scissors.
You will also have to remove the top of the bag collar at the top of the cloth bag by releasing the fill tube from the inside of the cloth bag.
All of the parts are located on our website, www.govacuum.com. If you have any questions about the repair, you can get me on a live help, chat service located in the top right corner of our website. I'd be happy to walk you through this.
Thanks,
Chris Jones
GoVacuum.com
Posted on Sep 30, 2008
SOURCE: Need belt for Everstar 5990 vacuum cleaner
Thanks ljong, I got the belt you suggested at Home Depot, and it worked perfectly!!!
Posted on Nov 17, 2009
  • 382 Answers
SOURCE: How to replace Kenmore canister vacuum filter.
I believe it faces toward the housing
Posted on Dec 19, 2009
  • 50 Answers
SOURCE: Vacuum has new bag but won't pick up dirt. Cleaned
It's clogged somewhere. Disconnect the hoses where you can and check for obstructions. Run a coat hanger down the hose if you need to to clear the obstruction.
Posted on Jan 02, 2011
I am vacuuming spackle dust from sanding walls and my electrolux canister continues to open. What should I do?
Fine dust from sparkle will clog a bag or filter very quickly even though the bag is not full or even close to full. The air can't pass through the bag so it is popping the door open. Drywall dust can ruin a vacuum motor very quickly. I use a shop vac style vacuum with a cartridge filter that still clogged up after just a few minutes of vacuuming the dust but I can take the filter outside and hit it against something and use a small soft brush to clean it.
Jan 28, 2018 | Electrolux Vacuums
How do I clean out nutone cv556 filter bag?
There are 3 options: 1) Use another vacuum like a shop vac to clean the filter bag while in place. 2) Wrap a trash bag around the bottom of the canister with the dirt can removed. Tighten the trash bag around the metal can and smack or shake the filter bag. This will prevent dust from escaping into the air and on you. 3) Grab the filter bag towards the top where it locks into the can. Pull the filter bag towards the center of the can to fold it into a C-shape. This can be hard to do, so do not be afraid to pull. Once folded into the C-shape, the bag should come out easily. Take the bag outside to shake off any debris. To put back in place, use the C-shape method again, and fold out to form a full circle. DO NOT wash the bags out with water.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
Central Vacuum Intercom and Whole House Audio Systems
May 22, 2014 | Broan-NuTone CV556 Cyclonic Bagless...
Need filter everstar vc 9550
I'm needing a filter for my everstar 3 stage heap vacuum model bck 9550, do u know where I can purchase one?
Oct 27, 2013 | Eureka 431A Optima Bagless Upright Vacuum
I've put in new bag and filters and there is dust coming out of the air vents. Where am I going wrong.
If a previous bag burst then it may just be the residual dust from that. I suggest you start by taking out the bag and filter and purging by switching on for a minute (don't actually vacuum with it and take it outside before you switch it on)
Eventually there will be no dust coming out then replace the bag and filter and if it is still blowing dust out then you will need to look for another problem.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Miele Cat & Dog 326i Bagged Canister...
My vaccuum cleaner is an EVERSTAR 1200. I turned it on - everything appears OK until I realize that it is not suctionning. I cleaned out the canister - made sure the vacuum was not obstructed. Still no...
First clean the filter on top of the canister, do not wet it, blow it and get all the accumulated dust out. Then check the hoses for obstruction. There should be an emergency valve on the rear part, if it is open, you better ck the hoses.
Aug 29, 2010 | Vacuums
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Windsor sensor says bag is full when its not
Are you vacuuming up fine particals like pet dander or just large amounts of regular dust? Also when was the last time you replaced your filters?
Just some sugestions.
Mar 17, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
There are no known vacum bags for a model wd06350 vac
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
Feb 09, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Do you know what a filter bag looks like in a central air vac system?
The unit displayed is a Beam Electrolux central vacuum power unit. It has a 15litre dust bucket which does not need any dust bags.
If you take the bucket off you will notice a white shiny weighted bag hanging down. This is the filter. The good news is, it is a self cleaning filter.
Dec 03, 2008 | Beam Industries 2775 Serenity Plus Central...
Vacuums Logo
196 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
