Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
I have the same problem, Bissell (user guide says 7901 and 8910 series) it's not spraying water, soap - nothing. Belt is fine, filters are clean, i've done everything the users guide offers.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
cnm
Posted on Sep 30, 2010
How to trouble shoot and repair at home Bissell proheat 2X water will not spray from floor nozzel ?
Check your User's Guide. Cleaning the filters may do the trick. Contact Bissell Consumer Care at 1-800-237-7691
Sep 17, 2014 | Bissell Vacuums
Soap mixing with water on bissell pro heat 2
Filter clog problem. Check your User's Guide for filter cleaning.
Jul 04, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
My bissel Pro Heat 2 drains all the soap in to the clean water resevoir mixing the two together. Why is this happening?
Sounds like a filter clog problem. First check and clean the filters. Your User's Guide can provide you with the specifics. Bissell Consumer Care is at 1-800-237-7691
Jul 04, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do I fix the problem on my Bissell model # 7920-5 carpet and floor cleaner the water won't spray out onto the carpet
First check your user's guide for filter cleaning. There are two filters both small that need cleaning after each use. If that didn't clear it up call Bissell Consumer Care at 1-800-237-7691
Jul 01, 2014 | Bissell Vacuums
I have a ProHeat Bissell 8910 Series. Won't release or pick up
heatman101
yoi
Mar 20, 2010 | Bissell 8910 ProHeat Clear View Upright...
Manual for Bissell Powerwash Deluxe cleaner
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 17, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell shampoo machine will not spray either water or soap
heatman101
yuet
Oct 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1697w Powersteamer
http://www.bissell.com/images/UserGuides/1697_207.pdf
go to bissell.com on the right hand side is the link were you type in your model number. it will take you to it you click more info and it opens a page to access the user guide. i had the same problem and after looking at the user guide found i had a broken belt (near the flow indicator there is a section that can open use a flat head screwdriver to pry it open and you can see the belt) i dont know if that will work yet b/c i just found it so im on the way to get a new belt. hope this helps
Jul 31, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Sprays soap, but not water
My Bissell is quite fussy. Sometimes I have to wiggle and push down the tank before the water will start to flow. The water doesn't flow properly if the soap container is low - I fill it with water when rinsing. It has a viewport with a red cross that turns when the water flows. Sometimes just removing that and the white filter below (and putting them back) makes it go. Mine is easy to take apart - 6 screws in the base unit and the top comes off. There are two water tubes going into the handle hinge under where the water tank goes - very easily squished or damaged. Last time the water stopped flowing, I ran it with the cover off and just fiddled around with the tubes and away it went. Maybe it is spraying soap only. The water flows up through the handle to the finger valve and heater. Some people say the heater in the upright/handle gets plugged. I haven't had that apart, but it should be easy to bypass the heater.
Sep 07, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
394 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
