Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
My compartment doesn't open and does not disolve the detergent
Probably for the past week my compartment where I put my Electrasol tablets in doesn't open. I end up with all the detergent left in the tab. It doesn't disolve at all. Whats the problem?
  • 523 Answers
If the door opens and it doesnt disolve the water isnt hot enough
Posted on May 30, 2010
Soap not dissolving in dishwasher. stays in compartment
Hi, dishwasher detergent stays in the compartment because Bosch has designed a gap at the top of the compartment that feeds water onto the detergent before the cover opens. This has possibly been done to soften up deteregent tablets and help them dissolve.
The result is a solidified mass of wet detergent that doesn't come out of the compartment when it opens, and slowly dissolves onto the dishes leaving them coated with alkaline detergent at the end of the cycle. The residual lump of detergent is in the compartment or on the bottom of the dishwasher (refer photo).
The solution is to remove the compartment cover and look for the small gap at the top of the compartment as in the photos. Clean the surface and fill the gap with epoxy glue. This will keep the detergent dry until the cover opens, allowing the detergent to fall freely out of the compartment._1583.jpg
Jun 23, 2010 | Dishwashers
Not cleaning low pressure smells hot looks like
Sounds like the dishwasher is not getting enough water during it's fill cycle due to low water pressure on supply line or the dishwasher pump is not working correctly. Could be obstructed with food matter, etc.Hope this helps
Jul 30, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
I have had my dishwasher for 3 years. In the past few days the tablet that i put in hasnt been disolving and washing the dishes. The compartment where you put the tablet opens its just the tablet doesnt...
I would say you are not getting any water flow since the water dissolves the tablet.
When starting it listen for the water valve opening and open door and see if there is any water.
If not it is probably the solenoid or a defective or blocked water valve which is not opening.
May 15, 2009 | Frigidaire Dishwashers
Dishwasher detergent "pacs" dont disolve anymore
Try reversing the bottom dish rack, it's likely blocking the dispenser door because it's put in the dishwasher incorrectly. Also check if there is anything in the back of the rack preventing it from going all the way in.
Apr 05, 2009 | KitchenAid KUDU03FT Built-in Dishwasher
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
ZANUSSI 695 Integrated Dishwasher
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Maytag model mdbtt70aww. After the end cycle. open the door and found detergent tab on the bottom and the main wash cover is opened. Maytag diswasher model MDBTT70AWW. Put dishes and so...
Check both arms are spinning freely when you have the machine loaded up normally.
If thats ok you could try powder instead of tabs if they are not disolving correctly
Apr 05, 2017 | Dishwashers
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
May 26, 2006 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
279 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
