Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
HANNspree Model # HSG 1053 22 white screen
My HANNspree 22'' LCD Monitor's screen is all white when I turn it on.
  • Mukesh Mukul Mathur
    Mukesh Mukul Mathur May 31, 2010
    when turn on Lg monitor model L1730s only white screen but no display.
Happyness
  • 7 Answers
SOURCE: lg 22 " monitor
This is called Burn In or LCD residue. Normal wear on monitors. To save this from happening quicker, when the monitor is not being used, just press the monitor power button and shut the screen down instead of using the screen saver. You can still leave the computer running, when your ready to use it again just turn on the power button to the monitor.
Posted on Jan 07, 2008
SOURCE: 22-inch Wide screen X2Gen LCD Monitor
I had the same thing happen. The power adapter needs to be replaced.
Posted on Aug 23, 2008
bammbammfran
  • 159 Answers
SOURCE: white screen
Hi.
Generally an all white screen scenario is caused by no signal from the monitors video board getting to the actual screen.
It could be as simple as a disconnected ribbon cable that mounts the two items.
It could also be a fuse on the back of the actual lcd screens circuit board. These fuses are usually labeled F1.
If you have a tester and the capabilities, in normal running mode the screen should be getting around 5 volts dc at this fuse.
The other problem could be a bad video board. These are not always repairable.
Bammbamm@ptd.net
Posted on Dec 14, 2008
  • 1572 Answers
SOURCE: westinghouse lcd monitor 19" - screen turns white
Fade to white might be caused by a bad or open connection to the backplane or bias voltage setting of the LCD. Check the connectors and cables between the LCD and the main board. Also, look for loose or disconnected ground wires.
Posted on Dec 18, 2008
SOURCE: Hannspree Monitor speakers wont work
I don't know if I caused the problem or not. I hooked up my new Hannspree HF237 monitor to my HP pc, and the sound wasn't loud enough so I hooked up my external speakers, and got nothing. So I disabled one without the other, and still got nothing. Now I can't even get the monitor's sound to come back on. Any ideas?
Posted on Oct 17, 2009
Vertical lines,sound ok .cant find the tcon board.is it integrated in the main board.?? Hannspree lcd tv.HSG-1235 32inch .
If you can't see a Separate tcon board then its integrated with the LCD panel. You have to replace the panel to get ride off vertical line.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 22, 2017 | Hannspree Televison & Video
WHERE DO I FIND A MANUAL FOR LCD TV HSG 1210?
Contact the manufacturer they will be glad to provide one
May 09, 2014 | Hannspree XV32 32 in. LCD Television
Hannspree 28" lcd only has
This is almost certainly a bad monitor and needs to be replaced, I wouldn't even troubleshoot it really. Basically half the screen matrix isn't getting any power most likely.
Some things you can troubleshoot if so inclined.
  • Hook the monitor to another computer (to rule out the current computer as a problem)
  • Replace the DVI cable (to rule out cable) although bad cables will typically cause color lose rather than part of the screen to be missing
Comment back if you need anything else.
Sep 08, 2011 | Hannspree HannsG HG281DP 28" LCD Monitor
My Hannspree 25" HF257 monitor
Ur tv have a dead 1 or 2 long board that call the LCD inverter boards.These 1 or 2 long LCD inverter boards job are to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long LCD inverter boards for the replacement.
Feb 28, 2011 | Hannspree HF257HPB LCD TV
Brand new Hannspree 28" tv when you switch it on screen just changes colour white to red all colours and nothing else
Get rid of this model!!!! The Hannspree and Toshiba models used a TFT LCD screen from a chinese manufacturer that has put out faulty components for the last 3 years. The Problem is in the way the Active Matrix Screen was manufactured. I would recommend you return this item immediately to the place where you purchased it and pick a different brand; also stay away from Westinghouse!
Sep 24, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
The 25 inch Hannspree LCD tv and monitor screen flickers.
Need code for hannspree 25" tv to use on a dishnet remote control
Sep 11, 2010 | Hannspree HH251H 25" LCD Monitor
Hannspree HF229H will not stay on
railbird56, Common problem for ALL BRANDS of "cold-cahtode-fluorescent-lamp" back-lit lcd monitors! Here are your options!!! Cheapest to most costly!! 1. Warranty repair. 2 DIY repair???? 3. Local or distant repair. 4. possible old + cash swapout with Hannspree for refurbished same model?? 5. Trade-in for new wide screen. My best guess on your monitor (no history) is that the unit's SMPS is in partial or full shutdown mode during it's black screen moments. How much do you know about "electronic ballasts" "switch-mode-power-supplys" and how to repair them?? 12fixlouie
Feb 22, 2010 | Hannspree HW191D LCD Monitor
The montinor is white
Chek the conection on the monitor,open the monitor and chek th conection of the lcd if is conected ok.i had tht problem to,and so i fixed.
Jan 17, 2009 | Hannspree HW191D LCD Monitor
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
778 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
Gregg Errera
Gregg Errera
Level 1 Expert
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
