Question about Dell Dimension 4600 PC Desktop
I need to install a memory card and want to know how to remove the side cover on the pc desktop
  • 1,472 Answers
Ehjh
If you go to this link it will show you how to open the side panel on your Dimension 4600.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/cvrop.htm#1138085
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on May 30, 2010
Pc powers up no beep and no vid can't even check bios no monitor
Hi, Turn off the computer and open the side cover by removing two screws. If you have a video card remove it and clean the connectors with alcohol and also the memory card connectors. Re install it and install it back the side cover and turn the power that should work for you. Get back to us if this information helps you solve the problem. Good day...
Jul 13, 2011 | Gateway DX4640-UBC01A PC Desktop
My p4 hp compaq is blinking green light insted of stand still green light
Does it power up at all? It could be due to the power-saving features putting it in stand-by. Is it the power LED or HDD LED?
Dec 30, 2010 | HP Compaq Business d530 PC Desktop
Remove Dimension 2400 cover to install memory
The cover is normaly one of the side pannel board, u need to look for a screw that would keep it in place(look for a screw that will be afixed on the sidepanel with the back panel, once you have removed the screw just pull the side panel with force using a small hump that u may find on the side/back panel corner.
It's little trickey and need some concentration, u may find the RAM slot on the Motherboard (The RAM slot will be aprox 3 to 4 inch in length, the RAM goes in only in one way...)
hope this helps
Feb 17, 2010 | Dell Dimension 3100 PC Desktop
NEED TO KNOW HOW OR WHERE TO ADD THE MEMORY CARDS IN MY DELL DIMENSION E521...HOW DO I OPEN THE TOWER
Hi There,
Should be very straight forward.
You can find full instructions here;
http://support.dell.com/support/edocs/systems/dimE521/en/SM_EN/index.htm
(this includes opening the cover!).
This model has 4 DDR2 slots and supports a maximum to 4Gb of RAM.
Regards,
MC
Aug 25, 2009 | Dell Dimension E521 PC Desktop
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
Installing memory cards
Obtain this free pdf from Dell support website-->http://support.dell.com/support/edocs/systems/dim4600C/en/H72280.pdf
Pages--57 to 61 Instructs on opening the cover and shows the parts of the systemboard.
Pages--68 to 71 Instructs on adding and removing the memory.
I hope this helps! Let me know if you have any questions.
Thank  You, Raph30
Jan 24, 2009 | Dell Dimension 4600 PC Desktop
How do I remove cover panel to install a wireless PCI card on an HP d530
i don think so u can remove the front panel more over if u try there re chance it might get chipped, at the both the side u wud be having screws try unscrewing and u can take it out and u will be able to fix in the mother board
Nov 01, 2008 | HP Compaq d530 PC Desktop
Installing a 2nd 256m ram memory card into packard bell imedia3501
Installing more memory to a pc is very universal and is done the same way into all computers out there.
First unplug your pc
Open the side cover or remove the cover debending on your pc case.
Turn the pc sideways on the floor or table
and locate the memory slots near the cpu.
In this pc we have 3 memory modules installed
In this case I would have to remove one of the original memory modules first before installing a new one.
But in your computer you should have a extra slot open.
Simply insert the memory into the slot and turn the white switches on the sides to lock the memory in.
And you are done.
Jul 01, 2008 | Packard Bell Computers & Internet
How do I instal two 1gb ram cards into packard bell 1508/2 pc
You need to take the pc apart.
open the case.
then you need to find the memory slots
Remove old modules or place new ones in if there is room.
Jun 27, 2008 | Packard Bell Computers & Internet
Installing memory
You can do this if both of your Desktops are using the same memory card or the memory card you need to replace from one to another desktop is supported by both the Desktop boards.
If you have not sure you can provide me the Model No for both the Desktops for more precise solution.
Feb 03, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 4600 PC Desktop Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
