Question about Garden
Weed eater starts but does reach speed to cut grass.
Try replacing or checking the Starter Housing Assembly
Part Number: 308671009. Look into the Starter Housing Assembly and make sure the square hole has not been rounded out. Also check the spring that comes out of the Starter Housing Assembly. Go to http://www.ereplacementparts.com/ryobihm-ry2600026cc-power-head-parts-c-7931_7937_117450.html for pictures and parts locations
Posted on Oct 07, 2011
  • 593 Answers
First, use the same oil and mix it the same from batch to batch, once you have made a batch (gallon or what ever, never add gas or oil to make more, use up the batch to the last drop, then make a new gallon). Be sure the air filter is clean, some are oil wet to catch more dirt, clean and spray it with a spray cooking oil. Next: Look for 3 adjustment screws on the carb. should be three total. 1 screw is for idle adjustment. the other 2 should be close to each other, one is low speed fuel/air mix and the other is high fuel/air mix. Adjust the low fuel/air mix screw until it will idle un-added with the throttle then adjust the idle on the throttle to get a good idle speed. Next adjust the High fuel/air mix until it gets the RPM's you want it to have. It should go from idle to high speed with out hesitation or cough. .
Posted on May 30, 2010
Which is the best website relating to weed eater ?
There are lots of web sites on the internet which are offering information relating to cycle weed eater . All these are specially made for folks that are interested in finding quality information concerning cycle weed eater . For more information please see this website:http://www.4cycleweedeater.com/
Aug 09, 2017 | Garden
The weed eater starts but will not continue running, not even so much as to cut any grass.
you may need to burn out the muffle or take the carburetor off and clean the screen.
Jun 24, 2017 | Garden
How can I remove the cartridge head to clean?
Usually the cutting head will have a couple of plastic tabs you push in to release the spool cover and get access to the spool
Mar 06, 2016 | Garden
Weed eater turns but will not cut the grass
Start with carb adjustment. Turn out the low and high adjusting needles 1 full turn, then adjust the choke.
Sep 14, 2014 | Ryobi Garden
I have a craft man weed Eater 27cc. When I start
Check the motor hasn't moved up the shaft and separated the inner drive cable from the spindle.
Sep 03, 2014 | Garden
My Weedeater riding lawn mower will not move in forward or reverse after it has started
Check your drive belt that it has not slipped off.. also check your drive lever on the right side (speeds, neutral, and reverse). The mower uses this lever to angle the motor against the belt to move it..
It is most likely the belt or the angle misaligned if the engine is turning...
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
I have weed eater/poulan 22" push lawn mower. It
Hi goldengear...
Make sure you have installed the blade on the right way, if it is installed upside down then it will "beat" the grass instead of cutting it and make a terrible cut, also make sure the blade is good and sharp.
The rough running may be due to trash in your carburetor, I would advise to clean your carburetor and also check you fuel tank for trash, water,etc. if there is any trash,water,etc in there then you need to also clean the fuel tank.
Do one more thing and check/clean/replace your fuel filter if you have one.
Please take time to rate me
Aug 18, 2011 | Poulan "Poulan" Push Mower
Does it make a big difference if i use a weed eater before applying round up?
Since Roundup works by being absorbed by the foliage and transported to the roots, I would think that cutting back the foliage would hinder this process, so you shouldn't use the weed eater before applying the Roundup.
Jul 27, 2011 | Roundup "" Weed & Grass Killer
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weed eater GTI 17 won't run on high speed
A couple of things may work...
Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
May 19, 2009 | Poulan Genuine Weedeater Part # 36006-128
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
