Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Fuel line is bad and needs replaced. need to know
Fuel line is bad and needs replaced. need to know what connections are inside fuel tank
  • 593 Answers
  • One line should be hooked to a small fuel filter or screen.
  • The other one is a dump or over flow that will put a small amount of unused fuel back into the tank.
  • You can buy this type of line at most Lawn Mower shops as a kit. 2 lines and a filer/screen.
  • You can use line for air shocks that fit some cars ie. Cadillac's
Posted on May 30, 2010
How does a weadeater edger pe550 gas lines hook up inside of the gas tank?
I am not familiar with your brand of machine, BUT... many machines have similar fuel line setups. Here\'s what I know.
Most carburetors have built-in fuel pumps that suck fuel from the tank. As the fuel pumps generally suck more fuel than the engine needs, there is a "fuel RETURN line" from the carb back to the fuel tank, which returns the excess fuel back to the tank. There is usually nothing attached to the end of this line inside the tank.
The "other" fuel line is from the tank TO the carb, and it usually has a tiny, weighted, fuel filter attached to a long piece of fuel line INSIDE the tank. This long, flexible, floppy piece of tubing allows fuel pickup regardless of how, what position, the machine is held.
The purpose for this set-up is threefold:
  1. The filter, of course, is to keep "trash" out of the fuel system and,
  2. The "long" fuel line inside the tank is to allow the filter/pick-up end of the fuel line to move around in order to pick up fuel from ALL points inside the tank,and
  3. The weight is to forcefully "carry" the filter/pick-up intake to the low point ["bottom"] of the tank regardless of the orientation of the machine and fuel tank!!!
On the machines that I replaced the fuel lines, to replace the suction line I had to use a longer than normal [when finished] length of line.
I first had to "fish" the filter, weight, and any nipples and or washers out of the tank.
  1. I then inserted the new line into the tank from outside through the small hose opening hole.
  2. To start, I put MUCH MORE [extra] line into the tank so that I could fish-out 5 or 6 inches thru the filler opening, allowing me to finish the connection of the filter, weight, nipple(s) and/or washers outside the tank where I had room to work!!!!!
  3. The use of nipples with washers expands the hose enough to keep the assembly from easily falling or pulling from the tank.
  4. Once all of the "in-tank" assembly was done, I then gently pulled the extra fuel line back out of the tank hole, thus pulling the weighted filter and connectors back into the tank. I left enough "loose" tubing inside the tank to allow the weighted fuel pick-up end to reach anywhere inside the tank.
  5. The final step was to route the line to the suction nipple on the carb, cut the line to proper length, and attach it over the carb suction/intake nipple.
Not being familiar with your machine, I can only hope this allows you to fix your machine! Good luck!!!!!
Jul 23, 2014 | Poulan WeedEater Hedge Trimmer 25cc Engine
How to repairor replace small gas line on craftsman chainsaw model 358.360260
Before you begin, make a mental note or take a picture of how the fuel line runs from the tank to the carburetor so you will be able to put the replacement in the same position.
On most chainsaws you need to take some wire, make a u-shaped end, which will be used to grab the fuel filter in the fuel tank. Drain the fuel in the tank. Disconnect the fuel line from the carburetor. Generally there are two lines on the carburetor, one for fuel, the other line creates suction used to pump fuel and is connected to the motor, not the fuel tank . Just disconnect the fuel line, it is usually on the side of the carburetor and will leak gas when disconnected. Once this is done, using the wire, gently grab and pull the filter towards the filler opening and using needle nose pliers grab the fuel line above the filter and pull. The problem you may have, is if the fuel line is in bad shape it will break, But once you have the filter off the fuel line, the fuel line can be pulled out from either the inside of the tank or from where it comes out of the tank and goes to the carburetor. Once it is removed you are ready to put the new fuel line in.
It is best to put the fuel filter on the fuel line next. It easier than trying to put it on inside of fuel tank going out. Spray some WD40 or equivalent, on the outside of the gas line, to help the line squeeze through the whole in the back of the tank, which it will have the go through. From the outside of the tank, where the fuel line comes out, fish some wire inside the tank and put the fuel line on the end of it, making sure not to pierce or damage the fuel line. If needed a piece of black tape will hold the wire better and help fit the line through outside hole. Once the fuel line is on the wire, pull it through carefully out the other side of the tank. It is best to use your fingers to pull the line through the outside hole, it makes it less likely the line will get torn or overstretched as line goes through the hole because of the extra rubber used on the line to seal the tank from inside and outside. Once the line is pulled through and seated, run the other end to the carburetor and you are done.
Oct 01, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Craftsman Gas Powered Blower Mode 358.794772: Fuel lines broken and need replacement. Have new parts from Sears. One fuel line goes to the carb and connects to the fuel filter inside the fuel tank The...
A special fuel filter must be on the end of the fuel lines going into the tank, the line should be long enough for the filter to move around by gravity to stay in the fuel as the tank empties.
Sep 13, 2013 | managemylife.com
I need instructions on replacing the line on our Remington Lawn Trimmer
Hi pwdw71...
You will need to go to the lawnmower/weedeater parts house with a sample of both lines to be able to replace the lines with the right size fuel lines.
Also check/clean/replace the fuel filter inside of the tank.
Also take your Mfg. and model number with you.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.
The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru and primed the carburetor by the primer bulb.
You will insert the big line into the fuel tank far enough to be able to install the fuel filter.
Free Answer...Please take time to rate me
Jul 04, 2011 | Electric Garden
Craftsman 28cc gas weedeater gas line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Jun 30, 2009 | Craftsman Garden
Fetherlight xt200 fuel line connections
Jim
Jun 27, 2009 | Poulan Garden
Location of fuel lines, where they terminate.
Just let me know if you need further assistance.
Jim
Jun 24, 2009 | Ryobi Garden
Fuel filter in gas tank is attach to hose and connect to ?
Jim
Jun 16, 2009 | McCulloch Garden
My homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
Jim
Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Loose Fuel Line In the Gas Tank
hi rhopdo
try to find the spark plug near the muffler(exhaust)
check where is the hole from the gas tank, connect the fuel line to the carb.
yours savumihai71
Dec 01, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
273 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
