Question about Refrigerators
Fluctuating temperature on both sides - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfluctuating temperature on both sides - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 31, 2010
Temperature gauge keeps fluctuating whats the cause
Fiats have a reputation for electrical/electronic problems as they age and even when they are not very old they can manage strange things that even sometimes defeat the dealers, though the same can be said of many modern vehicles. I used to look after a Ducato motorhome and fortunately didn't need to get involved with much electrical work - the only faults were caused by the coachbuilders rushing around and being careless and not by Fiat.
I am not sure if the temp gauge is driven by the engine management or is a traditional circuit but either way the temperature gauge is in effect a voltmeter of sorts. Assuming the gauge is ok, the reading will only fluctuate if the voltage in the circuit fluctuates and that could mean the supply voltage is fluctuating or the resistance of the ground path is fluctuating.
With the traditional circuit the gauge is supplied by an electronically stabilised voltage and the ground path resistance is varied by the engine coolant temperature sensor and fluctuations could be anything from a faulty instrument voltage regulator, through faulty wiring or connections to the temperature actually fluctuating.
If the gauge is driven by the engine management the same approximately applies but checking the circuit becomes much more complex due to the need for circuit diagrams and specialised test equipment, though these would not be needed just to check the security of the gauge in the printed circuit of the instrument panel.
Mar 18, 2017 | Fiat Cars & Trucks
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
Why would a 1994 Oldsmobile Achieva S quad 4 engine temperature gauge fluctuate between 195 & 220 degrees? The thermostat has been changed and the engine and radiator have been flushed. The normal...
either the thermostat is getting ready to fail or the temp sensor isnt working properlythese engines also leak fluid from rear side of head after getting hot so check that so may have air in system because of the blown head gasket
May 28, 2011 | 1994 Oldsmobile Achieva Special Edition
Fluctuating water temp. It is hot when I start the shower,
Iam guessing your using it faster than it makes hot water. May need a larger unit or a second one,in the system
Apr 10, 2010 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
Engine Temperature Fluctuation
fluctuation in temperature is usualy from low coolent level. a sticky thermastat could also be the culprit.
Nov 21, 2009 | 2004 Buick LeSabre
Psc25mstass freezer not cooling
I had a problem where the temperatures in both refrig and freezer wouls fluctuate. Would not geep ice cream frrozen in top of freezer but temp gauge would read 0. Even stranger would have stalagtites forming from the top shelves in the freeser (big ones). Still under extended warantee so tech replaced the mother board and iit is functioning well now.
Sep 30, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Temperature fluctuating
Fluctuating by how much? Maybe I can help you on this one
Aug 11, 2009 | Hyundai Motor 1998 Accent
CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Nov 10, 2008 | Kitchen Ranges
Door open signal flashing -
First check to see that the door switch is closed fully when the door is closed. Tape it fully shut to make sure
Jul 17, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
