Question about Acer Aspire™ T180 PC Desktop
Memory installation my pc came with 2x512mb of memory i added 2x1gb memory to empty slots but my pc would not work- i took out the 2x512mb and put the 2x1gb into the 1st 2 slots and it works fine can you tell me why it would not work with the 2x512 and 2x1gb in together
  • 57 Answers
Most likely it has to do with your chipset. You might also be trying to run the RAM in dual-channel mode. Some systems are extremely finicky in dual-channel. Next time you boot, try looking in the BIOS to check if dual-channel is enabled or not. If it is, try disabling it and putting the chips back in. You can also go to your motherboard manufacturer's website and check for BIOS updates, as they tend to help with things like this.
Posted on Apr 08, 2008
  • William Rodriguez
    William Rodriguez Apr 08, 2008
    Just so you know, what iqbal_del is talking about only applies to dertain chipsets, and it only applies in dual-channel mode.
  • 655 Answers
Bev,
all the DIM's must be of same type and same size to work, otherwise it creates problem, like no boot, boot with lowest memory etc.
There is no problem in your PC, its technical issue you can not use two ore more different type RAM at the same time in a motherborad.
Thanks
Iqbal
Acer desktp internal ram installation needed
I'm a bit confused....did you have all four of these in the ACER and are trying to put the 2x1GB into the Emachine? And that the 2x1 GB wouldn't work in the Emachine but they did in the ACER and that the 2x512 Acer cards worked in the emachine?
If that is what happened here is my best guess. The ACER MOBO will support 533/667/800 MHZ DDR2 RAM. The Emachine will only support 533 RAM. Iys possible the 2x1GB are either 667 or 800 MHZ and are not compatible with the Emachine but will work in the ACER.
Jan 23, 2012 | E-Machines T5082 PC Desktop
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
Want to upgrade memory to 2 GB. Desktop will not post up with 2x1GB cards. Every 2-3 seconds it makes a sound/tone. The fans would turn on but there is no signal to the monitor. However, it will post up...
There is no reset just because you added memory.
If you have 2- 1GB sticks, try both , one at a time.
Your system spec's and manual tell nothing which dimm banks are suppose to be used , and if you can install 2-1GB sticks,
all it says is it can handle 2GB.
Now it says 512MB, sticks, this could mean you can only use 4-512MB sticks to get too 2GB,.
Now it does not tell which dimms are used if you have 2-1GB sticks,
You have 4 slots, the first two and the second two, most times, you either use the second bank of each pair, or the first slot of each pair,
but as I said, your system does not say.
So you can try both ways and see if one of them work.
Sorry I can't be of more help,but you system has a poor manual
on memory placement.
Feb 14, 2010 | E-Machines T3302 PC Desktop
Memory Upgrade Problem
Some of the motherboard DIMMS got limitation. U need to check back the manual. Cannot simply insert different type of speed and capacity on each DIMMs.
Feb 13, 2009 | Acer Aspire™ T180 PC Desktop
Aspire t180 memory problem
check, if you motherboard support 2GB, or else start windows in safe mode with 2GB.
Oct 17, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire Memory problem
The read speed of your new memory is not compatible with your motherboard. It is a higher rate than allowed. The reason why it works when you have one of your old chips installed is because your PC will automatically drop the higher rate chip down to the one that is working. The reason it does not drop both new chips down to a suitable rate is because it has nothing to guide it like your compatible chip does. Always check the MHz on RAM chips and compare that with the acceptable rates listed on your motherboard specs. The good news is you can probably sell those chips and have money left over when you find upgraded compatible memory that is sure to be cheaper since it is slower.
Apr 11, 2017 | Acer Aspire T650 (AST650UC3601) PC Desktop
Dell Dimension E510 memory upgrade
Please check the type of RAM you are using.
You must return it to BestBuy and try using a Dell store.
Call Dell Accessories sale and they will be able to give to better options and it wud work too.
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Install 2 RAM modules of 1 GB
The other memory may be soldered in. Check your manual and see if it has any information on additional memory. If you only have on expansion slot you may have to buy larger memory chips. like instead of 2 chips 1 gig each you may have to purchase a 2 gig chip. Computer companies usually make the chip installation easy to get to on lap tops.
Jan 14, 2008 | HP Compaq nx6310 Notebook
Memory module
Your motherboard supports 533MHz memory modules, no more. If you put anything higher in, it will work, but only at the speed of 533MHz, so there's not much point in aiming any higher. Just make sure what you're buying is a DDR2 533MHz memory module, and it's best to get them in increments of 2. If you have 4 slots on your motherboard, get another 2x512MB modules of RAM. If you're running Windows Vista, it might be worth considering 2x1GB modules. I think that pretty much covers your question, if you have anything else to ask, feel free to reply.
Sep 07, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Acer Aspire™ T180 PC Desktop Logo
158 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
