Question about D-Link Air DWL-122 802.11b Wireless Adapter
Adapter does not detect wireless network
I'm putting this adapter on my desktop in another room. I know the adapter can find and connect to the network as I had it connected to a Tivo box. The adapter is from D-Link.
  • 33 Answers
Check to see if is compatible with tivo.
Some units are not compatible with tivos...
Posted on Jul 05, 2010
I have the Gateway 2wirewireless-G modem and router, how can i connect another desktop in another room to it?
1. Right-click the wireless network icon in the lower right corner of your screen, and then click View Available Wireless Networks. sammiller001_5.gif
2. The Wireless Network Connection window appears and displays available networks. If you don't see your network (should be named something like 2wire), click Refresh network list in the upper left corner. Click your network, and then click Connect in the lower right corner. sammiller001_7.gif
3. Windows XP prompts you to enter a key. The key should be one of the numbers printed on the bottom of your 2wire modem/router. sammiller001_8.gif
4. Windows XP will show its progress as it connects to your network. If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key-click Cancel and return to step 3. After you're connected, you can close the Wireless Network Connection window. Now you're ready to browse the internet!
Mar 05, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I have a DIR-615 router that I have no problem connecting my laptops with internal wireless. However, trying to connect my desktop with a DWL-G620 Wireless Adapter. It detect the network but will not...
The WPA key is the encryption key that is configured in the router's wireless settings and the wireless cards in the laptop and desktop needs to be configured with this encryption setting to allow the laptop and desktop computer to communicate with the router.
You can view the encryption settings in the router's wireless settings or on the laptop's wireless card settings and then apply these encryption settings to the desktop's wireless card (ie. the SSID and the WPA encryption).
Nov 15, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
I have a Belkin Wireless adaptor and a wireless router. The netgear adaptor I had before on my desktop got borken so I replaced with a Belkin adaptor. The new Belkin adaptor is not recognizing the wireless...
Hi, did you provide the network key/password when you setup the wireless conection on your computer? Is it detecting your wireless router (you should see your SSID or network name) when you click on your wireless icon (in the taskbar) and chose "show wireless connections". If you can acess to your router via it's configuration page(type the router's default IP address in your browser) you can go check the settings and change the key/passphrase if you dont remember it. If all of this is not working, you can also start from stratch. Reset the router to factory settings (check your manual) then reconfigure it the way you want, put the new infos in your wireless network connections properties and try again. let me know with more specific details if you still cant do it
Jun 08, 2009 | Belkin Wireless Desktop (F5D7000FR)...
Problem with 2Wire 802.11g Wireless USB Adapter
Were you using a different wireless adapter prior to the USB version you now have? Here is where I am going, It may be using the settings for the old network adapter.There could be a redundancy, this happens all the time, the best way is to start from scratch. Just use the wizard to establish a new connection. You may see the old connection while doing this, in which case I would delete it. If you rt click on my network, the icon on the desktop, and select properties, it will walk you through a new connection, this way you know that you are starting from scratch. Good luck, and let me know if this doesn't work for you, we can eliminate the obvious and look deeper, make sure to put the same encryption and key in when you set up good luck
Mar 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
No network detected to setup wireless router
You have to set a network connection on the computer. Go to the control panel and chose Network, the set a new one.
Jan 06, 2009 | Computers & Internet
Which adapter?
2wire usb adapter. i have mine in another room.
Mar 03, 2008 | Computers & Internet
Not detecting any wireless networks
You have not mentioned having a wireless router or access point to serve as the hub on an infrastructure network. I you have a router please let me know -- the instructions for the solution changes.
The following is an article to create an ad hoc network between wireless cards without a wireless access point or a router. If you ignore the steps about connecting to the internet with a wired connection and the internet sharing instructions. This will allow your machines with wireless adapters to communicate with each other (assuming the operate on a common band). The article goes on to indicate one machine with a wired connection can act as the "router" for the other two when it is on to allow them share internet access with the wired machine (the wired machine also needs a wireless card for this to work).
Ad-hoc networking access point
Jan 03, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
D-Link Air DWL-122 802.11b Wireless Adapter Logo
124 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
