Question about Home Security
My FERMAX 20440 it s not working. Cables are not conecte. I don't know what color cable match with numbers
SOURCE: HOOKED UP MY NEW TV
The problem is that the tv is set to 480I or 480P. Try changing the setting to 720P or 1080I and the pink color should dissapear.
Posted on Jan 10, 2009
joshter32
  • 82 Answers
SOURCE: I want to install a radio for 94 infiniti Q45 but
yes but you want to check your wires with a 12v tester to make sure of it if you have any questions my names josh you can call me 832 248 4144
Posted on Oct 30, 2009
  • 773 Answers
SOURCE: Cb cables came out for the mic. I need to know
here is a reference manual that has the mic wiring information that you need.
Wiring diagrams
Posted on Oct 22, 2010
dunnbiker
  • 8546 Answers
SOURCE: hi, I have a onkyo
Well, the TX-27 has an onboard FM tuner. Is the amp working for IT? If not, you have an internal problem or a switch out of position. Turn the volume to something reasonable before troubvleshooting.
Posted on Jul 09, 2011
  • 885 Answers
SOURCE: dewalt dw297 impact wrench does'nt work at all. the cables does'nt seem broken, so don't know what to look for.
A good place to start with Dewalt tools is the switch. Take the front off the handle and pull the switch out far enough to test the posts on the back. Plug the cord in and check for voltage where the cord attaches to the switch. No voltage, bad cord, replace the cord. If you have voltage, the cord is good. With some help, hold the switch on and check for current on the motor side of the switch. If no voltage, replace the switch. If there is voltage there, you are going to have to check the brushes, armature and/or field for continuity or shorts.
Posted on Jun 28, 2012
How to plug a wii to a proscan "32" tv
If the TV has an unused HDMI port, use the HDMI cable that comes with the WII . If not , then use the 5 cable Hi def cable . Match the colors RGB on the cables to the same color input jacks on the TV The red and white cables are the audio. Make sure you don't get the wrong red cable mixed up. Note the input number near the jacks you use on the back of the TV. Select that number with the input button on the remote to see the picture.
Jun 17, 2015 | Video Game Consoles & Games
No sound while playing a dvd or cd in my valor dvd headunit radio has sound just not when i play a dvd or cd
Make sure your cables are in right spot on both..
DVD player (if using the composite cables yellow white red)
on DVD makes sure it says Video OUT and color match
TV look at the back and dont just plug in cuz you see colors. look at rear.
On Back where they are at should say Video 1 2 3 whichever one has the red yellow white cables and say Video IN. match colors then try. should work.
Mar 02, 2014 | Car Audio & Video
What is the wirer color diagram 1999 toyota avalon car stereo radio wiring diagram radioconstant12v+wire??
Hi Slick, From my experience working on Toyota motor vehicles, they don't use colour coding. You'll need to identify the cables with a voltmeter and an used AA or AAA battery (like those from the TV remote). First find the constant power (which keeps the memory function of the set powered. Then by a process of elimination turn on the ignition and check each of the other cables until you find the ignition switched power. Check to make sure it' switched by turning the ignition on and off. To identify the speaker cables there should be a number of white cables with black tracer lines. Take any pair (removing a little insulation from the end to leave the metal cable open) and hold one cable onto the negative end of the battery and swipe the other cable end over the positive. As you do that the cable speaker will make a popping sound, where by you can identify which speaker is attached to what set of cables. Regards John
Oct 24, 2012 | Toyota Cars & Trucks
I don't know how to successfully connect a JVC AV-27220 (a television) to HR-XVC29SU (a DVD player). I have a set of blue/red/green cables, but the colors don't match the markings on the devices....
The standard colors are : White, Yellow and Red. If you match the Red of the TV, the White of the TV and the Yellow of the TV to the same colors on the DVD player, then all should work properly. It does not matter what color the cable is, match color for color on the devices. Hope this helps and good luck from a teacher to another teacher.
Oct 29, 2017 | JVC AV-27220 TV
Hi, I have a onkyo tx-27 quartz synthesized tuner amplifier and I'm trying to conect it to my tv , so I have the red and white cables and I did the conection with the speakers and there is no sound...
Jul 09, 2011 | Onkyo Audio Players & Recorders
Have just purchased Toshiba 32kv500b tv and as there is only one scary socket don,t know how to attach a dvd player can you help with this problem please?
Connect the cables from your dvd player to the connections on the side, not the back, of the tv. If you are using component cables, match the colors in the 3 top ones (YPbPr) and the red and white go down into R&L just above the headphone jack. If you are using composite the plug the yellow just above the R&L connections.
Jul 06, 2011 | Televison & Video
I buy a ps2 please tell me how can i install it in my bravia lcd
The PS2 comes with an AV cable. (Red, White, & Yellow). Plug those cables into the matching slots on the back of your TV. They are color coded. If the TV is newer and does not have a spot for AV cables they you will need to by the HD cables or Component cables to match what your TV supports.
I don't know of newer TV's getting rid of AV links yet. Once they are plugged in, change the TV video input to the one that you plugged the cables in.
Mar 01, 2011 | Sony PlayStation 2 (PS2) Console
HOOKED UP MY NEW TV WITH COMPONENT CABES TO THE DVD. THE COLOR IS PINK. CABLES ARE NEW. I KNOW I HAVE THE COLOR CABLES MATCHED CORRECTLY. COULD IT BE THE CABLE OR DVD.
Jan 04, 2009 | Astar LTV-3201 32 in. LCD Television
Don't know the conections of blue or red
If we're talking about the microphone cable wiring on a low impedance mic remember this. Cheap mic cables with XLR's on both ends often have no standard color code to follow. True pin 1 is ALWAYS ground (shield wire) but the other two wires could be any color of the rainbow. Look for small numbers beside each pin of the XLR connector and make sure that pin two on one end of your cable, is also pin two on the other end as well....etc. Special note: The XLR connectors set screws have reversed threads and it's the same for the XLR male plug in the bottom of the microphone as well.....Glen
Dec 24, 2008 | Shure Beta 58A Professional Microphone
New system - no color on screen
the cable colors have to match the tv ones if you have different colors on cables then look for the label on the cables saying video or audio (red)=audio (white)=other audio (yellow)=video EXAMPLE if the cable colors are different than the tv then if the label on the cables say video and the color is blue etc. then you have to put it on the yellow putin on the tv no matter the color. If it dosent work then try holding the cables in many angles try pulling them or anything unlit they work get something to hold them up if that dosent work then i think you should buy new cables. DGKME@yahoo.com for more questions
Mar 29, 2008 | Nintendo Wii Console
Home Security Logo
197 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
