Question about Brother DCP-7030 Digital All-in-One Laser Printer
Started machine and so the drum empty
My printer DCP730 is ink empty then i refiling but cannot red the paper and show ink is the empty when started machine that scan is also work is all right so plz solution can u give me and where is service center information in kolkata
thanks
  • 666 Answers
You want to go into the error count menu of the printer and clear current error count this lets the printer know the problem has been solved
hope this helps
Robb
Posted on May 30, 2010
Hi my samsung ml-1610 mono laser printer shows red light contineously i dont know what the problem is can u help me please
see, you have inserted the paper well. if not solved, your catridge have low ink or empty. so bring a new catridge or if you can, refill the catridge. 1610 catridge can be easily refilled.
Aug 27, 2011 | Samsung ML 1610 Laser Printer
My TX 100 will not print. I have replaced black cartridge thinking it would change things but no. The green button shows and the red one shows (the red one shouldn't) and when I press 'print' it...
Epson ink cartridges have memory chips. If you refill a cartridge it will still show as empty until the memory chip has been reset. The printer will not normally print if it thinks the ink is empty. This is to protect the printer as the ink is energized as it is used.
Refill ink sellers on line usually have the Chip Reset tool available to buy (SK168-II).
Apr 14, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to refill hp 818 inkjet cartridge
i have injected 5 ml black ink in my 818 cartridge and inserted in my HP deskjetF2418 printer but it is not working and showing empty signal
Sep 30, 2009 | HP DeskJet F380 All-In-One Printer
Screen says drum near end
Drum for Brother MFC-6800 All in One Machine
You can expect it to print 12,000 Page Yield
Whats the difference between a DRUM and a TONER Cartridge? The toner cartridge is a cartridge holding the toner (ink). The drum does the work to transfer the ink to the paper. You will need to replace the drum every 5-6 toner cartridges you use.
Sep 24, 2009 | Brother MFC 240C All-In-One InkJet Printer
My printer can't read the new ink level after refilling
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Dec 06, 2008 | HP DeskJet F4280 All In One Printer InkJet
Mp470 pixma
Do you still need help with this problem?
Regards,
Worldvet
Nov 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Aug 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Refill Toner Cartridge for Laser Printer
Nobody has a clue how to refill a laser cartridge with ink. :)))
OK< just kidding, here it is:
First of all, laser-cartridges have toner (a fine black powder) and not ink.
Second: There are 2 methods to refill a laser cartridge: dismounting it to get to the toner chamber (involves a lot of tehnical skill) or the melt-and-pour method (see here http://www.urefilltoner.co.uk/), but you need the melting device.
But because from your question i see you dont know a thing about refilling, better go to a refill center.
Feb 14, 2008 | HP LaserJet 1012 Printer
HP 2840 is printing light even after putting in a new cartridge
no, that is not the drum, it has a chip on each toner cartridge that send information back to the printers main computer, and that tells the machine how much is remaining.
Has the cartridges been refilled ? need to know before i move unto the answer.
Jan 03, 2008 | HP LaserJet 2840 Printer
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
Brother DCP-7030 Digital All-in-One Laser Printer Logo
116 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
