Question about Gateway 830GM PC Desktop
I miss i386 file - Gateway 830GM PC Desktop
    Guru:
  • 722 Answers
I suggest contacting the vendor for which you purchased the computer or the OS and get an OS disc. The file will be found on there - you can run a repair solution from there. Or, look it up at Google.com.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Posted on May 30, 2010
While installing xp sp3. Error message: file missing check i333
Are you sure i333 is not actually i386? The i386 folder contains all the files Windows uses to install XP. If you have XP installed already and it is asking for the i386 folder, it wants you to put the original Windows XP folder into your CD drive. If you are attempting to install Windows XP with SP3, there is something wrong with your CD. To avoid this problem in the past you can do this:
Copy Windows XP Installation Files to Local Hard Disk SourcePath Raymond CC
Feb 07, 2017 | Computers & Internet
Tip
How To Install East Asian Language Support In XP Without XP CD
  1. First, check to see if you have the i386 folder on your hard drive. This folder will have the East Asian Language Support files that you need to install. The i386 folder can be found here: C:\WINDOWS\Driver Cache\i386 or here: C:\i386
  2. If you cannot find the i386 folder, you will need to obtain a copy of the Windows XP CD and copy the i386 folder to a USB thumb drive.
  3. Click on the Start menu, open Control Panel, then open Regional and Language Options.
  4. Select the Languages tab and under the Supplemental language support frame, check the the box next to "install support for East Asian languages".
  5. Click on Ok or Apply, then you'll receive a dialog box which says that "The following file ' - ' is missing.." and it also allows you to specify a directory where it should be found. Click on Browse and select the "I386" folder on your hard drive or thumb drive.
  6. After the files are installed, you must restart your computer.
on Feb 26, 2011 | Computers & Internet
I miss this FILE, C:\WINDOWS\system32\DRVSTORE\ccdcmbm_1507EAA4009CCD3F133476A7176B42C0EDC3BF32\i386
Try to use the microsoft update function in your start button.
Its probably a service pack file there is missing.
Or try to upgrade the drivers for the mainboard.
Visit your manufactures homepage.
Good luck.
Mar 09, 2011 | Computers & Internet
Hi, i have a problem with my computer. When i boot it, something different happens almost every try. Sometimes, nothing happens and there's a black screen. Sometimes, it says that windows cannot run...
Find folder name: i386
and go to file txtsetup.sif
copy txtsetup.sif from I386 and paste in flash , next rename I386 to $WIN_NT$.~BT .Worcked 100%.
Apr 08, 2017 | Gigabyte GA-7N400-L Motherboard
My dell latitude x1 wants to reinstall xp pro. the problem is that he can not find a specific file in the I386 file. it does not have a cd-rom. also tryd to boot from a bootabll ubuntu netbook live...
We need to know what file is missing and does it boot at all, you may be able to run SFC from the command prompt to repair itself, if it boots up;
Nov 27, 2017 | Dell Latitude X1 Notebook
One of the disks in not readable and while booting i get a message of pci.sys file missing or corrupted and i cannot start the system
expand the missing/corrupt file from i386 on your installation media to the system32 directory on the server using the bootable OS CD, select the recovery console option, not the repair OS option.
Dec 21, 2009 | IBM x3400 Server
In My PC Error Shows NTDLR File Is Missing,How To
Method:1
1.Make the first boot device as CD-ROM
2.Boot the system with windows(operating system cd)
3.go the first repair(r) option
4.once u got the command prompt change you directory to X:/i386
copy x;/i386/ntldr c:
copy x:/i386/ntdetect.com c:
note:x:(cdrom) drive may change
and then reboot the system.
method 2;
boot with the operating cd and go the second repair option and repair the operating system
Dec 02, 2009 | Gateway 500GR PC Desktop
NTOSKRNL.EXE missing
NTLDR is missing  Press Ctrl Alt Del to Restart
----Windows XP users Insert the Windows XP bootable CD into the computer. When prompted to press any key to boot from the CD, press any key. Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Oct 19, 2008 | Computers & Internet
Windows Xp Home edition Installation
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
Jun 01, 2008 | HP Compaq Presario SR1420nx...
Windows XP Service Pack 2 shows asms missing
My understanding of this problem is as follows: When you put the Windows XP CD into the drive and switch on the computer Windows starts from the CD. In order to access the CD it uses the BIOS. However, at a certain point it decides to use its own drivers instead of using the BIOS. Oops! it doesn't have the right driver because your CD drive is too new, so it can't read the CD, and thus can't continue the install. The solution then is to copy all the necessary files onto a place where Windows can read the files. Solution 1 Do you have another computer? Take the hard drive out of the machine you are installing and put it into the second machine as a secondary hard drive. Switch on the second machine and copy the i386 directory and all its files and subdirectories from the Windows install CD on to the secondary hard drive. Remove the hard drive and put it back into the machine you are installing and switch it on. When Windows then asks for the missing file you can direct it to the I386 directory on the hard drive. This should be C:\I386. It will ask for the location of about 10 files. Give the same answer each time. Solution 2 You will need a bootable CD such as Hiren's boot CD, and a second CD drive. Put Hiren's into the primary CD drive. Put the Windows CD into the second CD drive. Switch on, and choose the mini XP Copy the I386 directory and all its sub-directories onto the hard drive. Again, when Windows asks for the location of the files direct it to the appropriate directory on the hard drive.
Feb 05, 2008 | Microsoft Windows XP Professional With...
Gateway 830GM PC Desktop Logo
27 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
