Question about RCA D52W19 52" Rear Projection Television
It is like looking at 3d in all three colors. i
I have a rca hdtv hd52w67 and it is like looking at 3d in all three colors. i dont know how to get to auto converge
  • RCA Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
78it is like looking at 3d in all three colors. i - e87380c.jpgclass=
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. Ifit is like looking at 3d in all three colors. i - 69189a5.pngo fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Aug 14, 2010
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
I have a 52" rca hdtv. the screen looks like its in 3d. can this be fixed? model# hd52w67
It seem like a convergence trouble. I tink it is a ITC222 chassis in this set. If it is, you probleme is eeprom for convergence need to be reprogrammed and cause no power on convergence board.
Apr 22, 2010 | RCA R52WM24 52" HDTV Projection Television
Have the HD52w67 rca. Have a 3d effect. know we have to adjust the lamps. we go to menu but we have no auto convergence. What can we do now?
Is there a manual convergence setting in the menu? if so try to adjust the level 1, 2, and 3 settings. If not try to clean the lenses with qtips and alchohol.
Mar 07, 2010 | RCA HD52W59 HDTV Projection Television
I have a rca hd52w67 projection tv and the screen looks like it is concaved,has three lines across the top and looks like it is in 3d. What is wrong with it?
The convergnce amplifiers have failed.
This is a common old-age problem.
This requires replacing the convergence amplifiers and possibly resistors and fuses. A repair shop would charge $300-$400 to repair.
If you are tech savy or know someone who is, thae parts will cost around $40.00. Search this site for specific instructions.
Good Day,
-Dan
Sep 10, 2009 | RCA HD52W59 HDTV Projection Television
Tv looks like it is in 3D
Sounds like your convergence amp board has gone out and will need replaced. If you feel like giving it a try yourself this web site has them fairly cheap and they have an 800 line if you need help determining your board number.
http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD52W59 HDTV Projection Television
Rca 7302rd5 56"hdtv tv looks like a 3d moive
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 03, 2009 | RCA R52WM24 52" HDTV Projection Television
The image on my hd52w67 looks like its in 3D
Your symptoms sounds like a damaged convergence IC’s.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
You may want to consult a Television Repair Technician, or repair this yourself. If you want to tackle this yourself, let me know, I can give you some direction for the repair
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 30, 2009 | RCA HD52W59 HDTV Projection Television
I have a hd52w67 rca that was working good for about six months, and all of sudden a red, green and blue line appeared when i turned it on, and now the picture is like a 3d video. i don't know what happen...
It sounds like your convergence chips went, if all the colors don't line up, if u do this and it still dosen;t work, then it is your convergence module. Can't tell u the cost as it varies, depending where you live.
Mar 24, 2009 | RCA HD52W59 HDTV Projection Television
Warped 3D vision on the screen
convergence is out? convergence is not available in setup menu? this points to eather convergence power supply out or you might wont to look at fl231 fuse.
Mar 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
201 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
