Question about Stanley Bostitch F21PL Nailer
How do i load the fastners into the f21pl? - Stanley Bostitch F21PL Nailer
  • 4,234 Answers
Pull the nail tension slider towarrd the back of the nailer. It should click into place. Load the nails throught the slot on the top of the long flat magazine. Press the tabs on the slider together to release it and it will provide the tension on the nails.
Dan
Posted on May 30, 2010
How do i replace the water intake valve?
Brand? Model number from serial plate. This like asking how to open a door. But is it a car door? House door? Is it a door.
Im sorry but could not manage myself.
Disconnect fill hose, there is your valve :-) the thing that the hose is screwed on to. Remove the top cover for front loading machine. Back cover/side panel for top loading machines. Locate valve. Unscrew fastners, or loosen fastner clips and replace it
Feb 13, 2016 | Washing Machines
Bostitch f21pl air leaking out exhaust
Usually, air leaking from head is caused by worn/ broken seal # 163823 that sits on top of the cylinder. Remove head and observe seal. If it looks complete, however it fits loosly on the cylinder, use rtv sealeant under seal. Otherwise replace. Good luck
Oct 18, 2012 | Stanley Bostitch F21PL Nailer
Senco shf15 not driving fastners all the way
Sounds like there is internally worn parts. Pull it apart & check it out.
Mar 31, 2012 | Senco SHF15 Manual Hardwood Flooring...
Bostitch F21PL nailer is leaking air out of the top exhaust?
could be the firing valve is sutck or has a pinched o ring or the cylinder seal is extremely loose or pitted.
Oct 25, 2010 | Stanley Bostitch F21PL Nailer
Looking for a manuel i can download
6
http://www.bostitch.com
support
service parts and documents
select f21PL
search
usage manual pdf
File was to large to attach
May 27, 2010 | Stanley Bostitch F21PL Nailer
HOW DO I REPLACE A BRAKE LIGHT ON A 1987 MR2?
Open the rear bootlid behind the engine and there are two carpet panels on each side covering the light electrics. they are held in by fastners, push each fastner at the centre to release them.
Remove the carpet panel to get access to the brake light. Twist the bulb holder and replace the bulb.
Then replace the carpet panels using the fastners.
Nov 09, 2009 | 1987 Toyota MR2
Contact head won't retract...seems to be stuck
Two things come to mind, both require disassembly.
First i would clean the area, and then relube the contact head. While cleaning that area and relubing, check the o-ring and the surrounding seals, they may be not properly alligned or sitting perfect.
Aug 08, 2009 | Stanley Bostitch F21PL Nailer
Remove hood insulator blanket
carefully pry the black plastic fastners holding blanket away from hood. these fastners snap into a bracket attached to the hood replace by inserting into the original hole
Dec 30, 2008 | 2004 Cadillac SRX
How do you oil a nailer?
first off some nail guns do not need to be oiled, but the gun you have listed does need to be oiled you just drip a few drops of oil in the hole where the air hose connects to the gun, but make sure that you are useing the right oil make sure it is pneumatic oil for air nailers. the gun should have came with some oil if it was bought new if not you can get the oil at Lowes, Home Depot, or any other home improvement store
Sep 30, 2008 | Stanley Bostitch F21PL Nailer
Stanley Bostitch F21PL Nailer Logo
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
