Question about Kenmore 73952 Gas Dryer
Series 90 gas dryer won't heat up-- replaced the ignitor that was bad but still no heating of the ignitor. I am getting 1.8v AC on the ignitor when the dryer is running.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. As you have already replaced the igniter the next thing to check is whether there is lint build up inside the exhaust vents, if there is then try to clean it. If everything appears to be fine then check the Thermal fuse attaches to the blower wheel housing of your dryer. It cannot be re-set and must be replaced when continuity between the pins is no longer present. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 30, 2010
  • jenbrennan99 May 30, 2010
    thermal fuse is good all thermostats are good. no air system blockages.
    any ideas
  • Rylee Smith
    Rylee Smith May 30, 2010
    If it is fine then shut off without igniting the gas (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
I have a Kenmore 90 Series gas dryer model num 11074902200 that won't heat up. the drum spins and the heat will turn on for a few minutes then it stops heating up. I replaced the glow igniter but the...
The flame sensor is fine because it is powering up the ignitor. The dryer does heat a little. It can be only one thing: The solenoids are aged and weak. They work at first then the heat up and quit.
How to video
Service manual and more HERE
Sep 08, 2011 | Dryers
My kenmore 5200 series gas dryer won't heat. My
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Kenmore Dryers
Kenmore 90 Series dryer will not heat up.
heatman101
Aug 02, 2011 | Kenmore Dryers
Kenmore 90 series gas dryer is running good, just no heat of a sudden
heatman101
Jun 30, 2011 | Dryers
KENMORE 90 SERIES GAS DRYER NO HEAT IS THERE A PILOT
heatman101
Jun 27, 2011 | Kenmore Dryers
My Kenmore Series 90 heavy duty gas dryer does not heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 19, 2011 | Kenmore Dryers
No heat,from my series 90 gas dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 08, 2010 | Kenmore Dryers
Sears Kenmore super capacity plus dryer won't heat up 90 series, about 7 years old. It heats up for the first few minutes and then gets cold
heatman101
Oct 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Dryer kenmore 90 series ,when we push start all we get is a tic
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 12, 2010 | Dryers
Sears Kenmore 90 series dryer
If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 17, 2010 | Dryers
Kenmore 73952 Gas Dryer Logo
80 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
