Question about Crosley AutoRama CR712 CD Shelf System
Hi I have a crosley auto rama record player with
Hi I have a crosley auto rama record player with cd and radio it looks like the motor isn't working can I get another motor anywhere?
Thanks
Rob
  • Crosley Master
  • 5,391 Answers
There's one way to check the motor. Take it out and connect a battery (if it's over 9 volts a PP9 should do it.) if it don't turn it's dead!
Then try CPC online parts people.
Posted on Jun 02, 2010
Is there a way to install a aux input on a crosley cr-9 juke box radio? Thanks
You would have to break into the cassette player's audio output section. By finding where the audio joins the main amp of the unit. You couldn't do it via the record input section as that uses a different pre-amp which would not be compatible with CD. Once you find the point where the cassette audio joins the pre-amp section of the main amp, you should be able to take a link, from a pair of phono sockets that you will have to mount somewhere on the unit. If you don't use the cassette anymore than you can disconnect it. If you do want to use the cassette then the best bet is to also install a switch that will switch between the two. You will not be able to have both cassette and CD wires linked to the same pre-amp input. As one will vastly reduce the volume of the other. Which is why you would have to install a switch between the two.
May 02, 2017 | Crosley Audio Players & Recorders
Crosley CR711
it sounds like the switch that indicates witch item gets power is gone,
Mar 16, 2014 | Crosley Audio Players & Recorders
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
Will my autorama crosley cr712 record player work without
The record player will work with out a remote.
The CD will need a remote, for operation control.
The radio will work with out a remote
Nov 04, 2009 | Crosley AutoRama CR712 CD Shelf System
Belt came off on my crosley cr49 record player
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 29, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Crosley CR704 record player wont work, HELP!!!
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Aug 01, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Crosley CR245 wont recognize any cd - blank cd-r or music cd
Check the manufacture's website for trouble shooting or firmware update
Feb 02, 2018 | Crosley CR248 Turntable
Crosley AutoRama CR712 CD Shelf System Logo
230 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
